What fuel managemnent for this buildup?
Old Jun 22, 2004 | 03:14 PM
Mentat Ghola's Avatar
Default What fuel managemnent for this buildup?
92 b18a block, arp rod bolts, PR3 pistons, new reings bearings, PR3 head, type R valvesprings, CTR cams, PR3 IM and TB, all the bolt-ons. (not cheap crap either)
Im wondering:
What sized injectors?
What fuel pump?
Do I need a FPR?
P.S. Im geting Hondata s100 for this motor. Redline will be 8500, daily driven.
While im on topic, What timing belt should I use? And are GSR head bolts usable? What water pump should I use? It has an ITR oil pump, im wandering if a GSR or B16 water pump will suffice.
Old Jun 22, 2004 | 03:27 PM
respectblades's Avatar
Default Re: What fuel managemnent for this buildup? (Mentat Ghola)
if you've gone that far why don't you jsut get arp head bolts
timing belt you can probabley do a search
your injectors shouldn't be much larger
maybe 310s
depends on how overbearing the power is for the stock injectors
Old Jun 22, 2004 | 09:30 PM
Default Re: What fuel managemnent for this buildup? (respectblades)
I was hoping I could use stock injectors, and just widen the pulse with the Hondata. And money is always an issue, Im buying this swap, and the guy has GSR head bolts, i want to know if theyl work.
Old Jun 23, 2004 | 12:02 AM
TECH43 RACING INC.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mentat Ghola &raquo;</TD></TR><TR><TD CLASS="quote">92 b18a block, arp rod bolts, PR3 pistons, new reings bearings, PR3 head, type R valvesprings, CTR cams, PR3 IM and TB, all the bolt-ons. (not cheap crap either)
Im wondering:
What fuel pump?
Do I need a FPR?
stock injectors.
stock pump.
aem adj. reg. (wont fluctuate like the b&m)
timing belt: stock.
you can use the 8 short ls bolts, scrap the 2 long, and get 2 more short, or use gsr's.
use a 91 ls water pump. cheapest new.
fasst
Oct 20, 2009 04:15 AM
Dead CIVIC
Jul 3, 2008 01:48 AM
foam
Jul 21, 2006 12:02 PM
redGSRguy
Feb 15, 2006 02:23 PM
bigTom
Jul 11, 2001 09:37 AM
