About to upgrade some of my suspension, need to check something.
Old Jun 22, 2004 | 01:02 PM
Origin's Avatar
Default About to upgrade some of my suspension, need to check something.
just wanted to check and make sure, algthough im almost positive what the answer is, but just to double check. im about to buy some koni yellows and h&r race springs for my 88 crx hf. because of the swap i just installed the complete spindle from an 88 crx si for the fronts. will this conflict with anything if i order everything for the 88 crx hf?
Old Jun 22, 2004 | 01:05 PM
EL Vap133's Avatar
Default Re: About to upgrade some of my suspension, need to check something. (Origin)
Not that I can think of. Sounds good to me.
Old Jun 22, 2004 | 01:07 PM
crx_88_si's Avatar
Default Re: About to upgrade some of my suspension, need to check something. (EL Vap133)
I agree. make sure u get the proper rear struts!
Old Jun 22, 2004 | 01:37 PM
Origin's Avatar
Default Re: About to upgrade some of my suspension, need to check something. (crx_88_si)
cool. i guess ill go ahead and get the es master bushing kit while im at it and just replace all of it at once. when i finally get the car running and get all this stuff installed im not even going to know its a crx anymore.
Old Jun 22, 2004 | 04:26 PM
tolnep's Avatar
Im gonna do something similar but haven't decided what all yet. There are a number of other bushings that should be replaced, including I think lower control arms. At least on a later model HF (don't know if yours qualifies) the total cost of bushings is around 320 to 350 (the ES ones plus the honda/greddy extras).
Issues are the difficulties of replacing some of the bushings. You need an 80 ton press or have a friend or a machine shop that has one.
Old Jun 22, 2004 | 08:10 PM
Origin's Avatar
hey im about to order my koni's from a member of the forum and hes saying that the fronts of the koni yellows are adjustable. i thought you could get front and back both externally adjustable. im using this site as reference. http://www.importhorizon.com/koniyellow.html can someone give me any insight on this?
Old Jun 22, 2004 | 08:12 PM
fourthgenhatchB17's Avatar
Default Re: About to upgrade some of my suspension, need to check something. (tolnep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tolnep &raquo;</TD></TR><TR><TD CLASS="quote">
Issues are the difficulties of replacing some of the bushings. You need an 80 ton press or have a friend or a machine shop that has one.</TD></TR></TABLE>
I changed mine with a 12 ton press. They were a little stubborn but i got it done.
xjunkii
Suspension & Brakes
Apr 19, 2008 03:49 AM
grenade foot soldier
Suspension & Brakes
Dec 24, 2005 03:55 PM
ironchef25
10
Aug 26, 2004 12:56 PM
ironchef25
Jul 11, 2004 12:37 PM
