b16 mounts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">where can i get a complete engine and tranny mounts set to swap in a b16 to a 97 civic hb??</TD></TR></TABLE>
The motor should bolt right in. You may want to put some Energy Suspension inserts or something similar since the motor will be out. Also, if you have a chance, change the clutch, flywheel and anything else you may think you may have a headache with later, now since the motor is out. If you don't have enough money to do all that, I'd suggest you wait until you do because it'll save you more cash in the long run. If you still want to get brand new mounts go to http://www.majestichonda.com. Good luck.
no you will need a 99-00 SI rear tranny bracket, and drivers side mount (the part that bolts to the motor not the chassis). I used the b-series front tranny mount, not sure if i had to but i did.
crxh22project
Jan 31, 2005 06:52 AM
Jahtoot84
May 14, 2004 08:58 AM
