possible to weld un-like metals?
Old Jun 22, 2004 | 11:25 AM
hellas's Avatar
Default possible to weld un-like metals?
can stainless be welded to steel?
a welder is telling me the metals have to be the same. is that true?
Old Jun 22, 2004 | 12:53 PM
JimBlake's Avatar
Default Re: possible to weld un-like metals? (hellas)
There's hundreds of flavors of stainless, & hundreds of flavors of plain carbon steel. If you've got lots of money to spend (& lots of parts to waste) figuring it out, you can probably weld anything. You probably end up using a series of several fill-metals of intermediate composition.
http://www.ewi.org
http://www.aws.org
Old Jun 22, 2004 | 09:49 PM
deepgreengsr's Avatar
he is probably asking can he weld typical 304 stainless which is used in exhaust tubeing to his standard honda mild steel exhuast pipe. The answer is yes!!!! is it optimal? no but it will work and the wled will not break off or damage anythnig. It is kinda hard to weld them together. the stainless wants to flow more than the mikd steel but its not rocket science.
Old Jun 23, 2004 | 08:39 AM
hellas's Avatar
well im not sure of the exact metals.
i had another guy arc weld it without a problem
do you guys know if this will work? to be used as a crank pulley holder
b16bri
Welding / Fabrication
Oct 11, 2011 04:28 PM
QuangAlang
Feb 15, 2008 04:34 PM
vegaskurt
Jun 12, 2006 08:24 PM
RTW DC2R
Apr 25, 2006 03:28 PM
madcrossover
Feb 27, 2006 09:20 AM
