How do I check CEL for an OBD1 conversion form OBD0?
Old Jun 22, 2004 | 10:22 AM
Renegade's Avatar
Default How do I check CEL for an OBD1 conversion form OBD0?
I have an engine light on my Mini-me conversion with OBD1. How can I check what it is?
Thank You
Old Jun 22, 2004 | 11:46 AM
PHiZ's Avatar
Default Re: How do I check CEL for an OBD1 conversion form OBD0? (Renegade)
If you run pin A13 to ground, I think your CEL in your gague cluster will blink.
-PHiZ
Old Jun 22, 2004 | 02:56 PM
Renegade's Avatar
Default Re: How do I check CEL for an OBD1 conversion form OBD0? (PHiZ)
Thank you, there is a losse wire labeled engine light on the harness, that must be what it is for, I did not know what to do with it.
Old Jun 23, 2004 | 04:52 AM
JimBlake's Avatar
On mine, A13 is the wire that's supposed to go to the lamp itself.
D4 is the service-check connector. Ground that one & the ECU blinks the CEL. (If A13 is properly connected to the lamp.)
Maybe they're different? Which ECU do you have?
Old Jun 23, 2004 | 05:17 AM
boomslang's Avatar
Default Re: How do I check CEL for an OBD1 conversion form OBD0? (JimBlake)
Ground the wire on pin D4. All OBD1 ECUs are the same in that respect.
Old Jun 23, 2004 | 08:54 AM
PHiZ's Avatar
Default Re: How do I check CEL for an OBD1 conversion form OBD0? (boomslang)
Whups, I just looked at the pinouts real quick. Thanks for the correction.
-PHiZ
fin781
Aug 5, 2011 08:12 AM
shaggyeg6si
Jun 28, 2008 08:30 PM
1gEF-8
Aug 10, 2005 01:54 AM
turboZChatch
Sep 30, 2004 01:30 PM
KevronsEG
Jan 21, 2003 02:22 PM
