jdm front end question
Old Jun 22, 2004 | 09:58 AM
rough_draft's Avatar
Default jdm front end question
i heard that the radiator support is jsut about the hood latch.. so if you decided to use a cf hood and no hood latch would you still have to weld up the radiator support? or would stuff still not fit correctly? thanks
Old Jun 22, 2004 | 10:00 AM
elementmilwaukee
Guest
Posts: n/a
Default Re: jdm front end question (rough_draft)
jesus man, I don't know!
<---- post *****.. ;-) hehe lol.
Old Jun 22, 2004 | 10:09 AM
esponet's Avatar
i have seen people getho rig it so they don't change the rad support.
you don't need to change the whole thing just the upper part and the middle support. ("T") shape.
i would still change the upper part so it will look right and just incase you decide to run a hood latch later on you don't need to worry about it.
Old Jun 22, 2004 | 10:51 AM
Bbasso's Avatar
Your not clear on your question, but I'll take a shot at answering it.
The rad support connects the front end together, without it your fenders would never stay aligned among other things. If your changing the front end to JDM from USDM you will need to either, make the openings for the lights bigger or just replace the damm thing which is the right thing to do. Now if your just adding a CF hood to a USDM front, I would use the stock hood latch and then add the hood pins for extra security, but some people don't.
Old Jun 22, 2004 | 05:54 PM
Default Re: jdm front end question (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Your not clear on your question, but I'll take a shot at answering it.
thank you very much
lPat
Jan 10, 2008 02:04 PM
br'Y'an
Oct 5, 2006 02:22 PM
LoneAutosport
10
Jul 21, 2005 08:35 PM
b16_madman
15
May 27, 2004 07:28 PM
Big Teggie
Jul 6, 2003 09:56 AM
