H22 in a 88-91 crx
I have a 1990 DX CRX with an 89 si D16A6 motor in it and it had A/C in it. Someone cut the A/C plugs off but the cooling fan plug is their but it's not working... just need some help
My fan is hard wired now so it runs only when I turn in on. I'm trying to make the wiring back to stock so it works right.
Modified by H22HondaCRX at 5:06 AM 6/23/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22HondaCRX »</TD></TR><TR><TD CLASS="quote">what are you saying </TD></TR></TABLE>
You are an idiot?
You are an idiot?
Damn- enough edits?
He wants to use the A/C fan along with the radiator fan... ** I think **.
Tap a wire from the the radiator fan to activate the relay for the A/C fan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22HondaCRX »</TD></TR><TR><TD CLASS="quote">no i do not have a h22 in my crx it is a 1990 hf whit a 89 si motor in it i want a h22a in my crx but it is hard to coum up whit $1950
Trust me, it will cost more than $1950 to get that engine into a crx.
wtf is wrong with this guy^^(h22crx)^^ this is why i dont do drugs
man, maybe i cant read but i still dont know what your question/ coment is..
ps. if you dont have an h22 crx change your info and screen name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drussell4801 »</TD></TR><TR><TD CLASS="quote">look where he's from
HAHAHA!
Ok -
"ok my crx dose not have the a/c in it no a/c fan it . there no a/c lines
someone how had the car befour me cut the a/c plugs and 4 my cooling fan to work it is hard wired . "
So take the fan out then since you don't have A/C!?!?!?!?!
Or are you trying to redo the A/C system and make it work? Is the whole A/C system there, but the A/C fan wires are cut and hard wired? You want to return the A/C wiring back to normal and make the A/C fan run like it's supposed to?
EDIT - wait? I read it again.
Is it that your radiator cooling fan wires are cut? The previous owner took out the A/C and cut the radiator fan wires too and just hard-wired them?
</TD></TR></TABLE>HAHAHA!
Ok -
Ok iether i'm really dumb or to smart to understand.Because none of what this guy is asking makes any sense.Here is a hint learn some english and how to make complete sentences,And then ask the Q's again.As for right now all i can make out of this is that maybe he is asking if he should take out the secondary fan for the a/c.If thats the case just leave it in i took out my compressor and stuff after my swap but left the fan in because it helps to cool the radiator faster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loaded Butane »</TD></TR><TR><TD CLASS="quote">And I thought rednecks around here had bad english.</TD></TR></TABLE>
I'm sure they do coming from MS....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">Here's what a non-A/C system needs for the radiator fan wiring. Just follow the red line!</TD></TR></TABLE>
At least you're trying to help, thanks for the diagram!
Very good, you're one state away so I guess that makes you so much better..... A lot of usless replies without much help.
Anyway, this is exactly what's wrong with this board half the time. People with lack of knowledge that can't reply with anything but remarks about bad English, where he's from blah blah blah
What you need to do is trace the wiring as shown in the diagram and make sure that the circuit is in fact getting current as it should. It's really hard to say since we don't know what's been done to the car. If the wiring check's out ok, then you should look into the thermo switch on the back of the block and/or the thermostat. Something else that wasn't mentioned is does your car's temp gauge work? Just throwing around some ideas...
</TD></TR></TABLE>Very good, you're one state away so I guess that makes you so much better..... A lot of usless replies without much help.
dude
I think we honestly didn't understand what he was asking. And by us making a little fun of him, maybe next time he will try a little harder to put his words into regular sentences. That was my plan anways..
but i do agree with you about the board being fucked up.
Oh, and by the way, this isn't a HELP ONLY board. This seems to be more like an online community most of the time.
Also, I meant no offense to this guy by talking **** about him being from West Vagina. I was just having some harmless fun.
Why are you so sensitive? Do you wear dresses?
<U>by the way, he has modified his original post in this thread, so what you're seeing is not what we saw when this thread first started. It was nearly impossible to decipher</U>.
The following was what it said originally:
someone how had the car befour me cut the a/c plugs and 4 my cooling fan to work it is hard wired "
just roll with it man, roll with it. And get some help for that wearing dresses thing..
iGoneRacing_GSR
May 11, 2004 05:11 AM
