What OIL PAN fits a JDM B16A1??
My plug is stripped and I want to go to Honda and buy a new oil pan...Which one fits the first gen B16? I just hate seeing all my Mobil 1 on the floor!
THanks!!!
THanks!!!
Honda won't be quick, here they only put in orders on tuesdays if they don't have what you need in stock, then it takes several days after that to get it in.
From what I have been told, all honda B16 & LS oil pans are the same, and the GSR & ITR are somewhat different, but all will bolt up to a B series block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dran »</TD></TR><TR><TD CLASS="quote">I need one quick...I may just have to spend the extra at Honda.
So 99-00Si eh? I don't need to get a 99-00SiR one? </TD></TR></TABLE>
yes you do need the SiR pan since your in Canada. US Si and Canadian SiR are the same.
easy fix use a lengend drain bolt it's longer and catches the threads a b16 drain bolt doesn't it'll fit your problem without getting a new pan
hybrid1990crx
Feb 8, 2005 11:03 PM
