A/C AND OVERHEATING. IS THERE A CONNECTION?
Old Jun 21, 2004 | 05:50 PM
pr8elu8desi's Avatar
Default A/C AND OVERHEATING. IS THERE A CONNECTION?
recently i added a new rediator, and a thermostat, to my 88 si, it has been driving good without overheating like it has been, one day i turned on the a/c, not even for 2 minutes, my car started smoking, an the temp. gauge, went past H, for the rest of the day, my car was running hot, even after letting it sit for a couple of hours, if anyone can help, thanks.
Kal's Avatar
Kal
Default Re: A/C AND OVERHEATING. IS THERE A CONNECTION? (pr8elu8desi)
yes
Old Jun 21, 2004 | 05:56 PM
Default Re: A/C AND OVERHEATING. IS THERE A CONNECTION? (Kal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
does leaving the a/c off still have sumthin ta do wit overheating, because if possible id fix it, if sumone can give me sum help
Old Jun 21, 2004 | 06:05 PM
gen4vteclude's Avatar
Check the fans
Old Jun 21, 2004 | 06:11 PM
Default Re: A/C AND OVERHEATING. IS THERE A CONNECTION? (gen4vteclude)
i thought that changing my thermastat would make my fans come one but i dont think it does because after the car overheated an i turned it off the fans weren't on, what should i do to get them to work?
Old Jun 21, 2004 | 06:13 PM
Behan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr8elu8desi &raquo;</TD></TR><TR><TD CLASS="quote">i thought that changing my thermastat would make my fans come one but i dont think it does because after the car overheated an i turned it off the fans weren't on, what should i do to get them to work?</TD></TR></TABLE>
make sure the fans will work when a connected to a 12 volt source. if they do check your coolant temp. sensor.
Old Jun 21, 2004 | 06:18 PM
Start by checking the fuse, if good, check for power at fans with test light, if no power, check fan relays and fan switch(not sure where it is on your car). You should find a problem some where, if you do have power at the fans, try jumping power to them,also make sure the grounds are good for the fans. If all else fails, and the fans dont come on when you jump power to them they are probably bad.
AaronJ
Sep 23, 2007 05:20 PM
GREENMOB$TER
Feb 8, 2007 09:15 PM
FastHatch90
Apr 3, 2006 09:35 PM
-Darren-
May 28, 2005 12:58 PM
JDM-EJ1
May 16, 2005 08:07 AM
