S2K oil filter on B16 results
Old Jun 21, 2004 | 04:29 PM
EFSiR's Avatar
Default S2K oil filter on B16 results
the 2004 S2000 oil filter will fit on B16. I noticed 5-8 psi increase in oil pressure.
HTH
Old Jun 21, 2004 | 04:37 PM
marieT1GRL's Avatar
Default Re: S2K oil filter on B16 results (EFSiR)
Old Jun 21, 2004 | 05:23 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFSiR &raquo;</TD></TR><TR><TD CLASS="quote">the 2004 S2000 oil filter will fit on B16. I noticed 5-8 psi increase in oil pressure.
HTH
Did you change the oil too?
Old Jun 22, 2004 | 11:40 AM
my_slow_civic's Avatar
Funny, I thought all honda filters are the same now.
Old Jun 22, 2004 | 10:58 PM
Chubz's Avatar
Default Re: S2K oil filter on B16 results (my_slow_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic &raquo;</TD></TR><TR><TD CLASS="quote">Funny, I thought all honda filters are the same now.</TD></TR></TABLE>
yeah crappy honeywell (fram filters)
Old Jun 22, 2004 | 11:17 PM
ragerized's Avatar
Default Re: S2K oil filter on B16 results (Jelly Bean)
i just recently bought a 02 s2k oil filter for my car, im changing the oil tomorrow, mines made by toyo roki
Old Jun 23, 2004 | 12:54 AM
Two_K Si's Avatar
Default Re: S2K oil filter on B16 results (ragerized)
Isnt also $9 I recently picked up 15 jdm honda oem oil filters made by nippon. I plan to cut one open and examine to compare to other honda filters. BTW, the s200 filter is identical to the large hamp filter.
Old Jun 24, 2004 | 03:12 PM
doublejz's Avatar
Default Re: S2K oil filter on B16 results (Two_K Si)
i heard that the honda oem ones, prevent from having a dry spot on start up. It holds the oil from draining back down or something thats what honda claims anyway
Old Jun 24, 2004 | 03:31 PM
Nic's Avatar
Nic
k&n oil filters!!!
Old Jun 24, 2004 | 03:39 PM
Two_K Si's Avatar
Default Re: S2K oil filter on B16 results (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">i heard that the honda oem ones, prevent from having a dry spot on start up. It holds the oil from draining back down or something thats what honda claims anyway</TD></TR></TABLE>
All oil filters have this feature. It is a valve in the oil filter called the anti-drainback valve (ADBV) You can see it at the bottom of the filter when you look in it.
Old Jun 24, 2004 | 04:38 PM
LSVTEC 91 Civic's Avatar
Banned
HTH
Thanks for the info, I'm going to get one for my next oil change
Old Jun 24, 2004 | 04:51 PM
Jim Truett's Avatar
Default Re: S2K oil filter on B16 results (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks for the info, I'm going to get one for my next oil change </TD></TR></TABLE>
Most people that notice a change in oil pressure with a different filter fail to factor in the fresh oil in the pan has not had any viscosity breakdown yet. I would be surprised if the oil pressure was still 5-8 psi higher at the end of the oil's service life.
Old Jun 24, 2004 | 04:53 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si &raquo;</TD></TR><TR><TD CLASS="quote">
All oil filters have this feature. It is a valve in the oil filter called the anti-drainback valve (ADBV) You can see it at the bottom of the filter when you look in it.</TD></TR></TABLE>
Not all filters have an anti-drainback valve, but all of the premium ones do. You also should look for a silicone valve because they tend to seal better.
Old Jun 24, 2004 | 05:35 PM
hondaguyef's Avatar
I believe fram oil filters do NOT have the adbv. At least I know about 2 years ago they didn't! So, NO, not all oil filters have this feature
redline870
Oct 6, 2008 08:57 PM
MidwestAutoWorks
Honda S2000
26
May 26, 2007 07:42 AM
lowlavar
Honda Civic (2006 - 2015)
Sep 11, 2006 07:27 PM
JDMInspired
Honda Civic (2001 - 2005)
10
Jun 7, 2006 05:13 PM
Si Erik
26
Sep 8, 2003 06:02 AM
