What is this part called? Its on the sway bar
Ok guys, I really need your help. I need to change this part. Dont know what its called so I cant do a google search on this.
It is the vertical part consisiting of rubbers and washers held by a bolt and nut which holds the sway bar to the shocks (or so I believe). It is just behind the front tires.
I found it on the majestic honda site but am searching for some after market manufacturer to save some bling blings.
http://www.hondaautomotivepart...R+ARM
It is on the right hand side of the image above from 29.6..7..5.........22
btw..this is for a 93 accord
thxs man..u guys are awesome..
since the rubber has hardened and the bolt and nut were rusted so i plan to change them all 29, 6, 7, 7, 5,6,6,5,7,7,6,22 (its basically a 4 washers and rubbers with connectors in between)
My friend told me it would be difficult to get the bolt open, so i may have to cut it and just replace the entire unit.
Any suggestion where I could find this..besides the honda dealer?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mozzy »</TD></TR><TR><TD CLASS="quote">thxs man..u guys are awesome..
Any suggestion where I could find this..besides the honda dealer?</TD></TR></TABLE>
if u're replacing anything in the front, dont worry about bushings or bolts being stuck. i've redone my whole front suspension, and brakes and i had no problems with stuck bolts.
now for the rear, the LCA's get stuck.
got some OE replacements for mine at autozone. something like 20 bucks, no big deal
exist12
Nov 29, 2009 10:52 PM
96 GSR-T
Suspension & Brakes
Mar 11, 2008 07:21 PM
