1.6 head on a 1.5 block
i need to know if i can put my 1.6 head on my 1.5 block. i have the intake and the wirring.what i need to know is do i need the ecu for that motor.and do i use my 1.5 dizzy or a 1.6 and what about fuel injectors?( it's going in a 91 honda rex hf)
thanks.
If your talking about a 1.6 sohc(non-vtec) from a 88-91 si then yes you can put the head on with no problems since you say you have an hf its already wired for mpfi.the dizzy from your 1.5 will work fine, if you dont have the one from the 1.6.as for choice on ecu's it depends the pm6 ecu's from 88-91 si's have a more aggresive fuel curve than the hf pm8 ecu.the 1.6 head from si have a more agrresive cam and slightly bigger injectors So if you use the pm8 it will run but you wont be taking full advantage of the motor not to mention the pm8 ecu has stock rev limiter of 5,500 rpms.So basically to sum it all up if your going to swap the head then you might as well get a complete one with dizzy and everything to take full advantage of the 1.6 head.
isotopesope
Feb 28, 2002 04:52 PM
