Vtec After Dyno Tune
Old Jun 21, 2004 | 08:11 AM
brian2903's Avatar
Default Vtec After Dyno Tune
Hi guys, I've done the dyno tune last thursday on my H22A Accord, and the tuner help me tune down the Vtec to 4500rpm.
After everything's done, I can hear the vtec kick in at 4500rpm, however, until the car go up to 5000rpm(stock setting), I finally can feel the vtec is pulling.
I was just wondering do they need to input more fuel or air if they tune down the vtec, or everyone have the same result after dyno tune? If so, there's actually no point to have vtec down tune. Am I right?
Old Jun 21, 2004 | 08:48 AM
Nick H's Avatar
New User
Default Re: Vtec After Dyno Tune (brian2903)
the problem is that vtec advances your timing when it engages, and most aftermarket piggyback systems can't advance the timing down to a lower rpm...the vafc's can't, that's for sure...you can play with the air fuel maps all you want, but it's the timing that's creating the sudden surge...
Old Jun 21, 2004 | 12:17 PM
b_ron007's Avatar
AEM EMS can control vtec while also adjusting fuel and timing. timing makes a big difference.
Old Jun 21, 2004 | 12:19 PM
fw190bvi's Avatar
Default Re: (b_ron007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_ron007 &raquo;</TD></TR><TR><TD CLASS="quote">AEM EMS can control vtec while also adjusting fuel and timing. timing makes a big difference.</TD></TR></TABLE>
thats why stand alone &gt; piggy back
Old Jun 30, 2004 | 08:18 AM
brian2903's Avatar
Hey Guys, here's my dyno graph. Please advise.Thanks.
http://f2.pg.photos.yahoo.com/...2.jpg
Old Jun 30, 2004 | 11:09 AM
swift535's Avatar
looks like you're running pretty rich on the top end. I don't have much experience with tuning (unfortunately) but I'd imagine that if you leaned out your top end a little you could get some more power
Old Jun 30, 2004 | 12:53 PM
Nick H's Avatar
New User
Default Re: (swift535)
what i would like to know is why on this dyno, the tourque and horsepower curves don't cross at 5252 as they should, and do on every other dyno i've ever seen....
giving it a big wtf?
Old Jun 30, 2004 | 01:09 PM
secksiman19's Avatar
Default Re: (Nick H)
is this an auto or a manny? btw i like your torque jump between 4.7-5.2k
Old Jun 30, 2004 | 02:44 PM
93CivicDxer's Avatar
ya thats what im saying the torque and the horsepower curves are gonna cross at 5250 sup wit that???
Old Jun 30, 2004 | 04:18 PM
4genaccordfreak's Avatar
you only got 148 WHP out of an h22a and u say thats tuned!??? wow.. ur motor is fucked then.. cuz a stock h22 has about 180WHP bone stock untuned... and i think you should set Vtec engagement back at 5g's because you have an insane torque dip between 4500 and 4800 rpm.. i dunno where u got this tuned or.. baselined at.. but i'd wonder about that motor.. ur only putting out the same power as a stock b16... those numbers are terrible
Old Jun 30, 2004 | 04:30 PM
The_Todd's Avatar
Farts in the shower
I would run a base set minus the piggy back vafc and see what you're running...then tune accordingly.
148whp out of a h22=very weak
Old Jun 30, 2004 | 06:03 PM
brian2903's Avatar
Thanks guys, that's totally what I think, 148 WHP is too weak from H22A.
Does auto tranny make any different from manuel? Coz mine is an auto.
btw, I tuned my vtec back to the stock setting
I'm now looking for a shop in midwest area to do dyno tune for me. Any one got suggestion?
Old Jun 30, 2004 | 06:14 PM
fw190bvi's Avatar
that is the shittiest tuning ever.....sorry to say......
you loose torque as your approach 5K.......you should be making hella amounts of torque (comparitive to honda engines) around there.........did they mess with the A/F maps and such??....cause honeslty, you shouldnt loose power @ vtec engagemnt point (which you are)
Old Jun 30, 2004 | 07:16 PM
Nick H's Avatar
New User
Default Re: Vtec After Dyno Tune (fw190bvi)
wait just a ******* second....this is the stupidest dyno i've ever seen...take a look:
tourque is on the right, horsepower is on the left...you can't even compare the two because they are measured on the graph using a different scale...that's why the ******* curves don't cross at 5252 rpm's....i'd say this particular dyno is kinda fucked up...you may even want to go to a different dyno because this one is inaccurate considering the stupidity of the graph...your numbers may not be as bad as they show on this particular dyno...hopefully not anyways...good luck
Old Jun 30, 2004 | 07:18 PM
fw190bvi's Avatar
Default Re: Vtec After Dyno Tune (Nick H)
regardless, i love how he lost power once vtec engaged.....
if they messed w/ the AF alot, id ask for my money back
Old Jun 30, 2004 | 07:28 PM
Nick H's Avatar
New User
also, what kind of tuning tools were used in this tuning session...
Old Jun 30, 2004 | 07:42 PM
brian2903's Avatar
Just normal wide band O2 senor
Old Jun 30, 2004 | 09:22 PM
it will have a lil more loss to the wheels, but it shouldnt be that much. maybe a new tuner is required? would you be willling to come to kc?
Old Jun 30, 2004 | 09:36 PM
azian21485's Avatar
Default Re: Vtec After Dyno Tune (secksiman19)
my friend's auto prelude dynoed at around the same numbers..like 150ish with i/h/e...always wondered about those motors
Old Jun 30, 2004 | 09:39 PM
Default Re: Vtec After Dyno Tune (azian21485)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azian21485 &raquo;</TD></TR><TR><TD CLASS="quote">my friend's auto prelude dynoed at around the same numbers..like 150ish with i/h/e...always wondered about those motors</TD></TR></TABLE>
which h22 did he have
Old Jun 30, 2004 | 11:27 PM
Nick H's Avatar
New User
i have an h22a with bolt ons (mugen header, 2.5" testpipe and exhaust, oem intake w/o filter, chipped GimpyRom p28, vafc, and butterfly system removed that dynoed 203 at the wheels...my motor might be a little healthier than most, but 150ish is abnormally low...i'd say 175-180 is normal for an h22a with bolt ons...
*edit, also, when i asked about the tuning, i meant how was the car tuned? piggyback system? chipped ecu? standalone, what?
Old Jul 1, 2004 | 12:26 AM
PLACEBO's Avatar
AMS is local...i've heard nothing but great things about them so i dunno.
Maybe this proves the whole "auto's come with different cams" arugument.
This is brian from clac right?
Old Jul 1, 2004 | 08:12 AM
brian2903's Avatar
Thanks every one
So, should I tune my car in other shop again ?
BTW, I'm tuning with VAFC-II
Old Jul 1, 2004 | 08:29 AM
EuRoBrO's Avatar
Sorry to get off topic but, what exactly is the Butterfly system? Is it easy to do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">i have an h22a with bolt ons (mugen header, 2.5" testpipe and exhaust, oem intake w/o filter, chipped GimpyRom p28, vafc, and butterfly system removed that dynoed 203 at the wheels...my motor might be a little healthier than most, but 150ish is abnormally low...i'd say 175-180 is normal for an h22a with bolt ons...
*edit, also, when i asked about the tuning, i meant how was the car tuned? piggyback system? chipped ecu? standalone, what?</TD></TR></TABLE>
Old Jul 1, 2004 | 09:32 AM
brian2903's Avatar
I don't mind going to KC as long as the tune shop is good.
btw, Both tune shops are located in MN.
Any one have experience/heard about them?
1.Propolsion
2.Elite
Thanks.
