h22 in 4th gen accord - Tranny question
how do you guys deal with the tranny, arent the accords cable trannies? and i know the h22's are hydraulic, so can you somehow make that work or will the accord tranny bolt up to the h22?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec96Lude »</TD></TR><TR><TD CLASS="quote">i know is obd2 but we already have everything we need to switch to obd1 so thats no problem. </TD></TR></TABLE>
You say no problem now. Have fun
WTF...
no one evers tells anyone or even SHOWS THEM that you have to tap the tranny if your gonna use the h22/h23 tranny in the cords''
there you go, that's my DIY for you..
i found out the hard way that it's a 2 step thing.. basically u need to drill the hole to size and then w/ the TAPPING BIT tap it (thread it)... What i did was just get the right size TAP and i started to TAP, but it wasnt working. The tap wasing threading the hole like it was suppose too... so i Jetted up to my hardware store (after consulting w/ will and ed) and explained to him what i was trying to do.. he told me that tapping is a 2step process.. basically u have to drill the hole to specs then TAP it (thread the hole u made) so basically u will need the tap that i stated above.. 10mmX1.25mm i proved a pic of the
it's a 11/32 size drill bit Bigger pic of the drill bit ... so 1st u need to drill the hole w/ the 11/32.. make sure u get all the scrap that get's left in the hole.. then insert the tap and slowing turn it! go in bout 1/4 of the way.. take it out and blow all the scarp metal out the hole.. repeat this till u get down far enuff so that u can screw that screw in .. .. hope this helps..
f22 tranny will bolt up to a h22a motor, and vise versa.. but if your gonna run a h22a motor w/ h22a or h23 tranny in an accord 90-93 then you need to tap the h22/23 tranny as i stated above
