eg h22 times not to good
Old Jun 21, 2004 | 06:47 AM
Cyberdx16's Avatar
Default eg h22 times not to good
I went to the track on friday night with my bro and one of my friends(drives a Lt1 trans am). Wasnt very happy with the times for the mods that we have done. the best i could do was a 14.6 and my bro did a 14.49. our exhaust was leaking from the header to the cat so that may have some effect preformace wise but probably not much. my digi aint working so i'll copy them straight from the slips. well hopefully next time we go we get better tires to drag in or learn how to launch better and maybe get it tuned and maybe be more prepared with the car.
mods/prep are
striped all carpets seats and spear were out
JDM h22a
15in c8's with aziens at 22 psi
hotshot header
custom/ghetto 2in ebay cat with obx 2.5in inlet with 2in outlet with 2.25 axleback magnaflow exhaust
warbro 255 fuel pump
custome cai with k&N air filter
agx shcks with gc's
run 1
r/t... .698
60'... 2.300
330... 6.411
1/8... 9.745
mph... 75.06
1000... 12.613
1/4... 15.021
mph... 93.94
I only shifted at 7200 rpm and i suck at getting her off line tire psi at 30
run 2
r/t... .355
60'... 2.319
330... 6.462
1/8... 9.763
mph... 75.66
1000... 12.579
1/4... 14.957
mph... 94.92
did really bad on the launch and ***** shifted again tire psi at 25
run 3
pretty much like run 2
run 4
r/t... .191
60'... 2.329
330... 6.329
1/8... 9.559
mph... 77.00
1000... 12.342
1/4... 14.696
mph... 96.18
tire psi 22
these were my bros run in the car (as u can tell by the times he is a much better driver than me) im just gonna show the 60', 1/8 & mph and 1/4 &mph too lazy to type in the rest
60' 2.221
1/8 9.500
mph 76.47
1/4 14.644
mph 95.79
tire psi 22 for the next 2 runs
60' 2.390
1/8 9.609
mph 76.89
1/4 14.723
mph 95.88
60' 2.232
1/8 9.412
mph 77.55
1/4 14.490
mph 96.97
Modified by Cyberdx16 at 4:19 PM 6/21/2004
Old Jun 21, 2004 | 09:40 AM
SleeprCivic's Avatar
Default Re: eg h22 times not to good (Cyberdx16)
Do you find that the Azenis work well at 22 psi?? Everything I've seen seems like they work best at about the factory psi (35ish)
Old Jun 21, 2004 | 10:14 AM
Honda_Tengoku's Avatar
Times do seem a bit slow. You are only pushing 93-97 MPH trap speeds. That definately doesnt seem right. your losing power somewhere. I made 94 MPH trap speeds on a 126 WHP D16Z6 hatchback, with a best of 14.8 if that tells u anything. Also u need to work on your launching technique. As your brothers Et's show he is getting much better launches. I ran 2.20 60 foot times on a 40 degree night at the track with my SOHC 1.6 on stock tires. U should atleast be making that or better on your Azenis. Did u drop your tire pressure immediately to 22 PSI or did u make some runs at a higher PSI? I dont have any experience with the Azenis but what I can tell u is that the tires I have dragged on, 22 PSI is too low. The lowest I go is 28-30 PSI on street tires (not drag radials).
Old Jun 21, 2004 | 10:46 AM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyberdx16 &raquo;</TD></TR><TR><TD CLASS="quote">
custom/ghetto 2in ebay cat with obx 2.5in inlet with 2in outlet with 2.25 axleback</TD></TR></TABLE>
Thats not good for performance.
You have stock ECU (unchipped)? Whats your Fuel Pressure at?
Old Jun 22, 2004 | 12:19 PM
Cyberdx16's Avatar
Default Re: eg h22 times not to good (turbogixxer)
the ecu is a stock p13. fuel presseure im not sure of right now but i am running rich. yeah the rigged up exhaust i think played a big role because i had big exhaust leak. a lot of people run aziens on low psi because of hte big sidewalls it has.
Old Jun 22, 2004 | 04:53 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
You have stock ECU (unchipped)? Whats your Fuel Pressure at?</TD></TR></TABLE>
how much do you think that would have an effect on the performance? (the exhaust part of the equation)
Old Jun 22, 2004 | 06:59 PM
H23AHybridEG's Avatar
Default Re: eg h22 times not to good (LsVtec92Hatch)
If I were you, I wouldn't be running a Walbro 255 LPH without an upgraded fuel pressure regulator. It would be better to run a Walbro 190 LPH because a Walbro 255 LPH pump is too overwhelming for the stock fuel pressure regulator... !
Old Jun 23, 2004 | 12:43 AM
poison's Avatar
Default Re: eg h22 times not to good (H23AHybridEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23AHybridEG &raquo;</TD></TR><TR><TD CLASS="quote">If I were you, I wouldn't be running a Walbro 255 LPH without an upgraded fuel pressure regulator. It would be better to run a Walbro 190 LPH because a Walbro 255 LPH pump is too overwhelming for the stock fuel pressure regulator... !</TD></TR></TABLE>
Get an FPR if you don't already have one. And check your ignition timing, etc. The littlest things can make a big difference.
Old Jun 23, 2004 | 07:51 AM
Newman's Avatar
New User
Default Re: eg h22 times not to good (poison)
Leaky exhaust (especially from the header) and those shitty 60' times will easily add a full second or more. All I can say with a H22 Civic at the track is practice, practice, practice. You need to get the feel of how your car is going to respond when launching it under certain scenarios and with different tires & suspension setups.
Jsherrod
Jul 5, 2015 06:15 AM
matt94z
Jun 10, 2007 12:59 PM
DJsilkyjr
Oct 24, 2006 04:49 AM
Cyberdx16
Jun 21, 2004 10:19 AM
fastwanabe
17
Mar 27, 2003 08:27 AM
