exhuast piping sizes....
Old Jun 21, 2004 | 06:09 AM
1.8_crx_what's Avatar
Default exhuast piping sizes....
ok, i know theres a lot of exhuast threads on here, but so far they all seem to be about types, not pipe sizing, so here we go, i have a mostly stock ls in a crx, i have an ES Oval for it, but i need suggestions on custom pipe sizes, im not goin boost any time soon, and i want it fairly quite, i think im lookin at 2.25 with a res, but not sure, any advice is helpfull, thanks guys!
Old Jun 21, 2004 | 06:43 AM
mamaboy's Avatar
Default Re: exhuast piping sizes.... (1.8_crx_what)
just bolt the muffler onto your stock tubing. When you boost, depending on your boost level, the optimum size is 2.5-3" 60-70mm
Old Jun 21, 2004 | 07:25 AM
Traction's Avatar
Default Re: exhuast piping sizes.... (mamaboy)
no stock exhaust with an ls swap is a power killer
sounds like you got yourself made already though, 2.25 is what I went with after researching because you still keep your low end torque and still get the h/p number in the high rpms (compared to 2.5)
If you want all top end go 2.5, more torque but not as much top end 2.25
Resonator always helps though
Old Jun 21, 2004 | 07:46 AM
spyz34's Avatar
Default Re: exhuast piping sizes.... (StealthEF)
Dumb question, but does the resonater replace the cat and is it smog legal for my yearly check?
Old Jun 21, 2004 | 08:03 AM
crx_88_si's Avatar
resonator does NOT replace the cat, just add it in between the cat and the muffler somewhere.
Old Jun 21, 2004 | 08:07 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">resonator does NOT replace the cat,</TD></TR></TABLE>
Looks can be deceving
Old Jun 21, 2004 | 08:28 AM
ok, i guess its cutsom 2.25, next thing is the cat.... cuz i know stock cats arent that size, what is recomended, and are they (what ever they are) easy to find, pretty much basic info btw thanks for all feed back
Old Jun 21, 2004 | 08:41 AM
Traction's Avatar
Default Re: (1.8_crx_what)
i used my stock cat, I even went to the junkyard and grabbed another stocker that was all plugged and rammed a bar through it and got rid of all that mesh, I use that cat on weekends and for races
Old Jun 21, 2004 | 09:40 AM
Default Re: (StealthEF)
sounds good, big sound difference between the stocker and the punched out stocker? and, please excuse my retardation, but when i go to the piping shop to get my exhaust done, what should i tell him about the cat??
Old Jun 21, 2004 | 11:36 AM
mamaboy's Avatar
crush bent tubing from the muffler shop is as bad as the stocker.....
Old Jun 21, 2004 | 11:47 AM
Default Re: (mamaboy)
i know a guy that does manderel bent
Old Jun 21, 2004 | 12:02 PM
HamiltonRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StealthEF &raquo;</TD></TR><TR><TD CLASS="quote">i , I even went to the junkyard and grabbed another stocker that was all plugged and rammed a bar through it and got rid of all that mesh, I use that cat on weekends and for races</TD></TR></TABLE>
This is making your loose power. Exhaust gases swirl up inside and actually restrict flow more then a stock cat.
The PROPER way to do it if you want the 'look' of a cat but no restriction is to find one of the cats with the bolts in each corner that hold it together.
1)Take apart the cat
2)Take the stuff out
3)Get a piece of straight exhaust pipe that just fits in the opening of the cat
4)Cut it to lenght and weld it inside
5)Close the cat back up
6)Bolt onto veichle
-Enjoy
Old Jun 21, 2004 | 12:49 PM
Default Re: (HamiltonRex)
i think that would loose sight of the quiet part of my exhuast, i dont want something that attracts the law from a 1/2 mile from my car, so.... on that note i think i may try to find some way to tone it down... any after market cats for 2.25 piping that keeps things quiet?
Old Jun 21, 2004 | 01:17 PM
crxguy05sir's Avatar
So i can use my stock exhausat with my b18b swap....sorry if its a lil off topic
Old Jun 21, 2004 | 02:25 PM
ZhaGg's Avatar
Default Re: (crxguy05sir)
Just go buy a 2.25" cat from Checker... They've got to look it up in thier catalog by size, not by application. They're like $80. I had a 2.5" for my old system and I picked up a 3" ID Cat for my new system (3" mandrel bent from Dr. Gas... )
Old Jun 21, 2004 | 03:36 PM
dr_latino999's Avatar
Default Re: (ZhaGg)
If you are worried about it being too loud, then just get a larger resonator.
Old Jun 21, 2004 | 05:18 PM
v8hunter03's Avatar
Default Re: (dr_latino999)
would you consider there to be too much back pressure with a 2"?
i ahve a B16a in my EF and i'm keeping the stock exhaust manifold and downpipe.. so is it worth getting 2.25"?
Old Jun 21, 2004 | 07:50 PM
Banned
Default Re: (v8hunter03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8hunter03 &raquo;</TD></TR><TR><TD CLASS="quote">would you consider there to be too much back pressure with a 2"?
Its usually smart to keep the same size as your header/downpipe flange, if you plan on upgrading to a header with a 2.25 or 2.5 flange, then change the pipe.
cd5ryan
Jun 18, 2010 04:49 PM
asianspeed
Feb 15, 2006 12:42 AM
E. Honda
16
Dec 3, 2002 12:57 PM
zcpowereddx
Jun 12, 2002 09:21 PM
itr501
Dec 4, 2001 12:47 PM
