b18c-r eagle 900hp h-beam or extreme duty rods w/ toda pistons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathan atwell »</TD></TR><TR><TD CLASS="quote">Pauter Ti rods. The absolute. </TD></TR></TABLE>
Definately if money isn't an issue, then this is the route I'd go.
Being that this is an all motor project, consider the fact that you don't need the worlds strongest rods and that a lightweight set of rods such as Probe rods will work well enough. The downfall to the Eagle rods is that they are indeed quite heavy as compared to stock rods. Also, consider going with CP pistons rather than the Toda's. The only reason to go with the Toda's is so that you can say that you have them.
What else are you doing besides pistons and rods? How much Hp are you shooting for? For $880 in pistons there are better opptions, imo. Eagle H beams will do the trick. even tho they are on the heavy side.
interested in high compression with out the detonation? I might have something for you if interested.
