Pedal bracket removal for broken clutch pedal
Old Jun 20, 2004 | 10:24 PM
Khmi's Avatar
Default Pedal bracket removal for broken clutch pedal
I have a 90 HB. About a month and a half ago my clutch pedal broke off... well the bolt that was holding the clutch pedal snapped in half with the other half off the bolt still stuck in the bracket. Well I just strated fix this problem now because i was at school and had no time. Today I dropped the sterring colum and took off the 6 bolts that i could see hold the the pedal bracket in place, and was that a b!tch. But the bracket still wont budge, there is no sign of movement with my hardest pull.
Any advice?...none of the vent are in the way yet.
Old Jun 21, 2004 | 10:57 AM
Khmi's Avatar
Default Re: Pedal bracket removal for broken clutch pedal (Khmi)
anyone?
Old Jun 21, 2004 | 02:10 PM
RCautoworks's Avatar
You need a swivle, deepwell 12mm and 2 six inch extensions. It is above the air vents and steering column. Have fun getting it out. Remove cotter pin that holds brake pedal to brake booster. There is also a nut and bolt for it. Remove the gas pedal from automatic pedal assembly and move to manual assembly so the cable plugs up, or switch cable. Install the clutch cable through gromet that honda left on firewall in factory location. Rebolt all the nuts to the car that hold the pedal assembly.
Ray Satomi
15
Jan 7, 2017 03:42 PM
quik89
12
Jan 18, 2007 11:00 PM
jdm206
12
Feb 21, 2006 03:22 PM
[626]95-GSR
11
Mar 29, 2003 09:13 PM
rasta420
Oct 18, 2002 12:33 PM
