Tick tick tick....... BOOM!!!! zc is ticking.
Old Jun 20, 2004 | 08:43 PM
ZC88CRX's Avatar
Default Tick tick tick....... BOOM!!!! zc is ticking.
The zc has been ticking lately and i'm too lazy to fix it if its not really a problem
Installed a dc header a few months back so the gasket might be leaking or something...... or i need a valve adjustment.... i dunno.
Now if the exhaust is leaking who cares, right? but if the valves need adjusting am i causing any perminent damage by not fixing it
btw - b16 is calling my name
Old Jun 20, 2004 | 08:51 PM
Full Race A6's Avatar
Default Re: Tick tick tick....... BOOM!!!! zc is ticking. (ZC88CRX)
Why would a leaky exhaust gasket cause ticking?
Old Jun 20, 2004 | 08:57 PM
ZC88CRX's Avatar
Default Re: Tick tick tick....... BOOM!!!! zc is ticking. (W O T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">Why would a leaky exhaust gasket cause ticking? </TD></TR></TABLE>
i dunno.... but thats what i found with some searching that i did
Old Jun 20, 2004 | 09:35 PM
Do you know how to adjust your own valves?
Easy way to see if the problem goes away I guess, even though I dont know how myself
Old Jun 20, 2004 | 09:51 PM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
adjusteding your valves is really no big deal
all you really have to do is the following:
turn the crank so that the cam shaft loob is point in up
stick the feeler gage inbetween the cam shaft and the rocker thing ( that the techincal term )
than do these a total of 4 times cus 2 loobs will be up at the same time
its 1.5mm on the intake cam
and 2mm on the exhaulst cam
O and to adjust the valve when the feeler is in the you losen the bolt (its a 12)
then un screw the screw or tight'n it to fit the gaug it should be tight but still move in and out
like a chicks frist
neonphire8604
Aug 14, 2006 12:17 PM
civicflow
Oct 1, 2004 04:37 PM
91teg
Mar 13, 2004 05:14 PM
*Boostwerks*
Sep 24, 2003 11:27 AM
4gzchatch
Apr 2, 2002 11:46 AM
