Other than being wider, 205 50R 15 vs 195 55R 15
Old Jun 20, 2004 | 08:39 PM
90Zcrx's Avatar
Default Other than being wider, 205 50R 15 vs 195 55R 15
I need a couple tires and the other tires on the fat fives I'm going to use are 195/55R 15. I really don't want to get 55 series, if I got a pair of 205 50R 15's and put them up front, would the sidewall size be about the same? The rears will need tires fairly soon and I would like to go to 205's but if there's that much difference in sidewall height I might just go with some 55 series tires.
Old Jun 20, 2004 | 10:13 PM
Two_K Si's Avatar
Default Re: Other than being wider, 205 50R 15 vs 195 55R 15 (90Zcrx)
205/50/15's are have a noticiably shorter sidwall compared to 55's. I had 195/55 and went with 205/50's and it got some whell gap all around now. One advantage other than the increased with is that with the 205/50's your gearing will be alittle shorter, so that gets a from me.
Old Jun 20, 2004 | 10:34 PM
eda6's Avatar
I got 205/50/15 in front
195/50/15 in rear.
There is a noticable sidewall difference.
My friend didn't notice it though. He likes 35" bfg's though.
In your case i think the difference will be obvious.
If you plan on buying new tires get what you want and don't worry
about how it looks.
Old Jun 21, 2004 | 04:52 AM
d357r0y's Avatar
the 205s on the front only will give you a more sure footed feeling when turning into corners.
check the autocross forum for more info on this subject
Old Jun 21, 2004 | 05:13 AM
B16A1-EF9's Avatar
I'd say go with a 195/50/15, works really nice on an EF.
Old Jun 21, 2004 | 07:35 AM
crx_88_si's Avatar
http://www.miata.net/garage/tirecalc.html
Old Jun 21, 2004 | 08:03 AM
90Zcrx's Avatar
Default Re: (crx_88_si)
Wow that's what I call a GREAT util. From the looks of it, the difference is going to be next to unnoticeable!
Weel
Jul 10, 2006 11:25 AM
ecahatch
Jan 27, 2006 12:09 AM
Timmy!
Aug 12, 2005 11:35 AM
EK k kay
Jan 20, 2005 03:05 PM
808State
Oct 19, 2003 04:42 PM
