Condenser fan not shuting off automatically
Hey Guys i have a gen2 integg & when the oil tem reaches to a point it turns on but the problem is that the condenser fan dosent turn off automaticlly like it should it stays on and drains my battery?? i checked the fan relay but its okay maybe a sensor but not shure were it might be?? have you guys ever had a problem like this??
It could be the fan control module, my 91 LS had the same problem.
They show where it is located in the helms.
It's in the center console, right by the radio.
About the size of a cigg pack or cass tape
They ain't cheap either, from honda 50.00-60.00 bucks
Try to find one in a junkyard.
I have a 91 RS doing the same thing. just comes on when ever it wants to. it will come on when i start the car everytime, even if it were 30 degree outside. I've been dealing with this for a long time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integ2 »</TD></TR><TR><TD CLASS="quote">I have a 91 RS doing the same thing. just comes on when ever it wants to. it will come on when i start the car everytime, even if it were 30 degree outside. I've been dealing with this for a long time.</TD></TR></TABLE>
Check out a helms or see my advice above.
HTH
HTH
my 92 did the same thing...just put a new plug at the fan motor...the contacts inside were bad and new relay just to be sure....works great now
