ABS Light
Im hoping the Vigor has the same ABS unit as the Accords or similiar. Ok my ABS light has been on for around 3 months now... i've just been ignoring it because I dont have the money right now to fix it and plus its not important until winter comes. Whats been bugging me, is the dam light is always on!
Now would taking out the fuses from the ABS unit thing under the hood work? Theres like a box in front of the battery and it says ABS unit on it, I took off the cover and there are 4 fuses in there. Is it okay to remove them??? just so that the light goes away
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V-Thang »</TD></TR><TR><TD CLASS="quote">Yes I know it means something is wrong. Basically the ABS is sytem is down, but regular brakes still work.</TD></TR></TABLE>
If the ABS is not functioning properly and you do not want to have to worry about it. I would disconnect the ABS brain which is located in your trunk on the right hand side behind your trim panel. Reason for this-if its not functions properly you never know what could go wrong..ie total brake failure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord »</TD></TR><TR><TD CLASS="quote">
Yea thats true. So it would be in the trunk under near the trim panel?? Im gonna go have a look today and see. Any idea what it looks like?? Just a socket, fuse, connector or something? PS: This is on a Acura Vigor
</TD></TR></TABLE>Yea thats true. So it would be in the trunk under near the trim panel?? Im gonna go have a look today and see. Any idea what it looks like?? Just a socket, fuse, connector or something? PS: This is on a Acura Vigor
Yea thats true. So it would be in the trunk under near the trim panel?? Im gonna go have a look today and see. Any idea what it looks like?? Just a socket, fuse, connector or something? PS: This is on a Acura Vigor</TD></TR></TABLE>
Oh its a Vigor.. then im not 100% sure. but it is a silver metal box. its the ABS brain and it has two sets of plugs going into it. just disconnect both of them.
