RSX TYPE S SPECS?
Old Jun 20, 2004 | 06:55 PM
MadnessRacing's Avatar
Default RSX TYPE S SPECS?
ANYBODY KNOWS THE SPECS ON THE TYPE S?
Old Jun 20, 2004 | 07:09 PM
ScuDC5's Avatar
yes: SEARCH
Old Jun 20, 2004 | 07:10 PM
ScuDC5's Avatar
so seriously... acura.com?
http://www.acura.com/models/mo...e=rsx
Old Jun 22, 2004 | 01:13 AM
The HamsterBall's Avatar
Default Re: RSX TYPE S SPECS? (MadnessRacing)
You should really do a search next time. It's not hard at all unless your prettty damn computer illiterate.
Ever hear of Acura.com?
Edmunds.com?
Google.com SEARCH : "Acura RSX Specifications"???
Anyways, here you go, now next time search.
"Engine Type
Aluminum Alloy 16-Valve, DOHC, i-VTECTM Inline 4-cylinder
Displacement (liters)
2.0
Horsepower (SAE net)
160 bhp @ 6500 rpm
200 bhp @ 7400 rpm
Torque
141 lbs-ft @ 4000 rpm
142 lbs-ft @6000 rpm
Redline
6800 rpm
7900 rpm
Compression Ratio
9.8:1
11.0:1
Fuel Injection
PGM-FI Multi-Point Injection
Emissions
LEV-II CARB
Acura Engines
Quicktime Video
VTEC
Tech-Demo
TRANSMISSION
RSX Manual
5-Speed Manual
RSX Auto
5-Speed Automatic Transmission with Sequential SportShift(tm)
Type-S
6-Speed Manual
Gear Ratios
RSX Manual
RSX Auto
Type-S
1st
3.267
2.684
3.267
2nd
1.880
1.500
2.130
3rd
1.212
0.984
1.517
4th
0.921
0.733
1.147
5th
0.738
0.571
0.921
6th
0.738
Reverse
3.583
2.000
3.583
Final Drive
4.389
4.562
4.389
CHASSIS
MEDIA
RSX
Type-S
Body Type
Unit Body
Suspension
Control-link MacPherson strut front/double-wishbone rear
Stabilizer Bar (front/rear)
23.0 mm tubular front/19.0 mm solid rear
Steering Type
Variable Power-Assist Rack-and-Pinion
Turning Circle, curb to curb
38.1 ft
Wheels
16" x 6 1/2" JJ Alloy
Brakes: 4-Wheel Disc with ABS (front/rear)
4-Wheel disc with ABS
Tires
P205/55 R16 89V All-Season radials
Suspension
Quicktime Demo
INTERIOR FEATURES
MEDIA
RSX
Type-S
Sport seats
Perforated leather trim seats (standard on Type-S, option on base RSX)
Driver's seat adjustable lumbar support
Leather-wrapped steering wheel
Metallic sport gauges
Front center console with tray and dual beverage holder
Lighted front beverage holder area
50/50 split fold-down rear seat
Rear-seat center storage and tray
Three rear beverage holders
Center console front and rear power outlets
Driver's and front passenger's seatback pockets
Power moonroof with sliding shade
Acura Music System with AM/FM stereo CD player and 6 speakers
Acura/Bose® Music System with AM/FM stereo cassette, 6-disc in-dash CD changer and RichbassTM woofer
Theft-deterrent system with electronic immobilizer
Automatic Climate Control System with air-filtration system
Power windows, door locks and hatch lock
Driver's auto up/down window with auto reverse
Steering wheel-mounted cruise control
Front door storage pockets
Dual overhead map lights with welcome lighting system
Keyless entry system
Large Interior
Small Interior
EXTERIOR FEATURES
MEDIA
RSX
Type-S
Heated, power-operated, body-colored outside mirrors
Keyless Entry System
16-inch aluminum alloy wheels
All-Season steel-belted radial tires
Heat-rejecting green-tinted glass
Galvanized-steel body panels
Body-colored front and rear bumpers
Speed-sensing, variable intermittent windshield wipers
Rear-window wiper and washer
Integrated rear glass antenna
Chrome exhaust outlet
Black chin spoiler and lower side sills
Chip-resistant rocker panels
Large Exterior
Small Exterior
Paint Process
SAFETY FEATURES
MEDIA
RSX
Type-S
Driver's and front passenger's dual-stage air bag supplemental restraint system (SRS)
Driver's and front passenger's side air bags with front passenger's height and position sensors
3-point seat belts with load limiters and pretensioners (front)
3-point seat belts (rear)
4-wheel anti-lock braking system (ABS)
5-mph bumpers (front/rear)
LATCH (Lower Anchors and Tethers for Children) child-seat mounting system (2 outboard rear positions)
Impact-absorbing crumple zones (front and rear)
Multi-reflector halogen headlights
Rear-window defroster with timer
Front side-window defoggers
Side-impact door beams
Side-impact floor beam
Collapsible steering column
Impact-absorbing interior surfaces
Safety glass
Nonprotruding switches and controls
Automatic transmission interlock features
Center high-mount brakelight
All-around visibility (289 degrees)
Rear window defroster with timer
Safety & Technology Demo
SRS
Quicktime Video
SRS
Interactive Video
ABS
Quicktime Video
GENERAL SPECIFICATIONS
RSX
Type-S
EPA Estimated Fuel Mileage (city/highway)
5-Speed Manual: 27/33
5-Speed Automatic: 25/34
6-Speed Manual: 24/31
Fuel Tank Capacity
13.2 U.S. gallons (50.0 liters)
Recommended Fuel
Unleaded 86 octane or higher
Premium unleaded 91 octane or higher
Crankcase Refill Capacity, including filter
4.4 U.S. quarts (4.2 liters)
5.0 U.S. quarts (4.7 liters)
Cooling System Capacity
6.8 U.S. quarts (6.4 liters)
7.1 U.S. quarts (6.7 liters)
Minimum Ground Clearance
6.0 in (152 mm)
5.9 in (149 mm)
Curb Weight
Manual: 2694 lbs
Automatic: 2771 lbs
Manual: 2767 lbs (1255 kg)
Weight Distribution (% front/rear)
Automatic 62/38
Manual 61/39
Manual: 61/39
Head Room
Front: 37.8 in (960 mm)
Rear: 30.1 in (866 mm)
Leg Room
Front: 43.1 in (1094 mm)
Rear: 29.2 in (742)
Hip Room
Front: 51.1 in (1297 mm)
Rear: 46.2 in (1174 mm)
Shoulder Room
Front: 52.6 in (1337 mm)
Rear: 51.3 in (1303 mm)
EPA Passenger Volume
81.2 cu. ft.
EPA Cargo Volume
16.0 cu. ft.
WARRANTIES
RSX
Type-S
Vehicle - 4-year/50,000-mile limited warranty*
Outer Body Rust-through - 5 year/unlimited-mile limited warranty*
Accessories - 4 year/50,000-mile limited warranty**
No scheduled tune-ups required for 110,000 miles***
*Ordinary maintenance items or adjustments, parts subject to normal wear and replacement, and certain other items are excluded.
**When installed at the time of new-vehicle delivery
***Does not apply to fluid and filter changes or periodic inspections. Please refer to the maintenance section of your owner's manual to determine all appropriate maintenance intervals.
INTERIOR ACCESSORIES
RSX
Type-S
CD Changer
CD Changer Magazine
Front All Season Floor Mats
Aluminum Shift **** 5MT
Aluminum Shift **** 6MT (Type-S only)
Billet Shift **** RSX, Red
Billet Shift **** RSX, Blue
Billet Shift **** RSX, Chrome
Cassette Player
Trunk Tray
Ashtray
Cigarette Lighter
Luggage Net
Titanium-look Interior Trim
EXTERIOR ACCESSORIES
RSX
Type-S
Moonroof Visor
Car Cover
Full Nose Mask
Wing Spoiler
Front Under Body Spoiler
Side Under Body Spoiler
Rear Under Body Spoiler
16" Machine Finish 7-Spoke Alloy Wheels
Splash Guards
Fenderwell Trim
Wheel Locks
Engine Block Heater
Fog Lights
Color-Matched Door Edge Trim
Gold Emblem Kit
Gold Exhaust Finisher
Gold 'Type-S' Emblem (Type-S only)"
Old Jun 22, 2004 | 02:48 PM
Default Re: RSX TYPE S SPECS? (The HamsterBall)
thanks is way more than enough!!
Old Jun 22, 2004 | 07:59 PM
DC5RK20A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The HamsterBall &raquo;</TD></TR><TR><TD CLASS="quote">
INTERIOR FEATURES
rear power outlets
None of this is available on the R. Is the RSX listed as seating for 5 in the states? Even the normal iS Integra is listed as seating for 4 here in Japan. And Japanese are on average alot smaller than Americans by far. And where is the 3rd rear cupholder? I'm not bitching about lack of features though, cause for one I hate sunroofs and this would turn me away from the RSX stateside because of it, would go with the EP3 instead and drop in a K20A.
Old Jun 23, 2004 | 09:11 PM
TEXN3's Avatar
Default Re: RSX TYPE S SPECS? (DC5RK20A)
i sure wish my 90 integra had a lighted cup holder. what will they think of next...
Old Jun 23, 2004 | 09:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5RK20A &raquo;</TD></TR><TR><TD CLASS="quote">None of this is available on the R. Is the RSX listed as seating for 5 in the states? Even the normal iS Integra is listed as seating for 4 here in Japan. And Japanese are on average alot smaller than Americans by far. And where is the 3rd rear cupholder? I'm not bitching about lack of features though, cause for one I hate sunroofs and this would turn me away from the RSX stateside because of it, would go with the EP3 instead and drop in a K20A.</TD></TR></TABLE>
He wanted the specifications for the RSX Type S, not the JDM DC5 Integra Type R.
Old Jun 24, 2004 | 03:13 AM
dwnshft02's Avatar
3rd rear cupholder is the one in the center console behind the e. brake.
Old Jun 24, 2004 | 08:08 AM
f1nal zeros's Avatar
It's funny, I can only fit 4 people in the car myself included. Unless someone want to jump in the hatch or sit on the tray . As for the moonroof, I have had the car since 01, and have actually used the moonroof a total of 5 times. I hate the moonroof. I live in Arizona where the temperature can reach past 120 degrees. Those 5 times I have used the moonroof where when I take my bi-monthly trips to LA, when I drive on the PCH.
AMG
Mar 10, 2006 11:54 AM
ajshades
14
Aug 8, 2002 05:36 AM
madtypR
Mar 3, 2002 03:09 PM
MrRyanFu
Dec 3, 2001 06:06 AM
iNteKra
Aug 26, 2001 02:22 PM
