Clutch issue
I just installed my new clutch and for some reason i can't get any pressure in the clutch pedal. I bled the clutch line by aiming the bleed screw on the slave cyclinder up and allowing the fluid to drip. the only thing i can think of is if i let the reserve get too low and it suxed air in the line. any help would be thanked.
You may still have some air in your clutch master. Double check it. Also, put a hose on the bleed nipple of the slave cylinder and with an assistant bleed the cyclinder in to a bottle of fluid. Look carefully for air bubble. When all the bubbles are gone and you have clear fluid you have a nicely bled clutch hydraulic line. Don't count on gravity to always purge air out of your line. DO it right and you will have pressure, assuming your clutch hardware is installed properly.
Draggin99Si
13
Jun 21, 2007 07:33 PM
