D16Z5 (1990 ZC) and B16 distributor compatibility?
My swap won't start.
It cranks, but there's no spark. It appears the wiring is OK, and I don't have any codes. I measured, and there's a current on the dizzy connector when I crank the car.
...so I suspect a broken dizzy, or rotor or something.
Can I test this with my D16Z5 (1990 ZC) dizzy, before I buy expensive parts, and find out thet it's something else.
Any suggestions furthermore?
There are 2 white wires in the dizzy plug. If you have them switched around you won't get any spark. Try switching them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 »</TD></TR><TR><TD CLASS="quote">I know there are 2 wires on the plug, but I'm not about to cut upp perfectly good wiring.
Do I NEED to switch the wires,..or is it just a thought?</TD></TR></TABLE>
I know what he's talking about, this is common in every swap there is. you dont even need to cut them up, just take a small flat head screw driver (smallest you can find, one for like fixing eye glasses) and find the 2 white pins, take them out, switch em, and voila! i bet it will start.
if not, its some
thing else.
if not, its some
thing else.
scooby2.0t
Sep 17, 2008 12:47 PM
It's*BOLO!!
39
Oct 3, 2006 11:06 AM
b16, compatibility, compatible, d16z5, distributor, dizzy, dohc, fit, head, honda, sale, switch, vtec, work, zc
