Just swap 2000 GSR motor in My 98 GSR.......some problems
I just took the car out for a drive. It runs good except the tach doesn't work + I don't think the secondaries are working either. I used the 2000 Engine harness that came on the motor. Is there anything different there from the 98->00 harness? I know the ECU plugs are different but I didn't think anything would be different with the engine harness.
It's running the stock 98 ECU. The other gauges work just not the tach. Also the secondaires don't work at all. But If I ground the wire going to the ECU the vacum accuator moves so for some resound the ECU isn't turning them on.
Found the problem.......
The 98-99 GSR's get the tach signal from the Distributer.
The 00-01's get the signal from the ECU.
So the 00-01 harness is not the same as the 98-99
JDM turbo DC
Oct 27, 2005 02:13 PM
underrated99si
Sep 3, 2002 01:58 PM
