engine shakes... motor mount inserts?
I have a 96 civic ex, and my engine shakes, especially when my AC is on. It makes my shifter shake and my exhaust constantly wiggle and it is very annoying. I've pretty much narrowed it down to the motor mounts.
Will motor mount inserts (like Energy Suspension) make this go away? Or do I need all new mounts.
Thanks,
Philip
EDIT:: I just searched a little and found that this will not work. BTW I didn't search before because this computer keeps having problems and I have to restart IE every few minutes.
Thanks,
Philip
with the energy suspension inserts, you will feel slight vibrations inside the car, i've got them in my 96 coupe, including a homemade polyurethane filled upper tranny mount, which makes for a lot of vibration inside the car, but i'm use to it.
i just got an im saying it could be the timing belt, anyone heard of this being a problem, i have 80k on my car, and if this is the problem i'm going to go ahead and get it changed
Look at the motor mounts and see if they are cracked or torn. And if you want it to go back to stock than don't use inserts that made to stiffen the motor and increase performance. Find a junkyard set or go to the dealer. I wouldn't recomend inserts in a bad mount, they even tell you that on the package
ctr status
May 8, 2006 11:24 AM
integra3586
Aug 28, 2005 08:14 AM
SOHC_Brian
Aug 11, 2004 11:30 AM
