painted stripping
Just needed to know how remove pinstripping that is actually painted on. Im thinkin a little wet sanding, but im not for sure. Is there anything you can buy that will remove those strippings.
peace
peace
You could try laquer thinner if it's on top of the clear. Is this the stock vinyl pinstripping? If so you could probably remove it wih a heat gun and then clean it up with some alcohol. But there is a strong possibility (depending on the age of your vehicle) that you may be able to see a shadow from the pinstipe once removed.
i dont know, but i can tell it was painted on, as it is impossible to remove. I was thinking that i would have to have it wet-sanded for them to be removed but i jsut wanted to know if there was an easier to make that happen. my car is blk, but they are greed and blue. it looks so gay
peace
peace
