WTB: OBD2 Knock Sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RageDzine »</TD></TR><TR><TD CLASS="quote">OBD 2 has the square plug right ?? We got them give us a ring, you still have our # ?</TD></TR></TABLE>
depends on the application
all DOHC VTEC B series from 90-01 use the same knock sensor.
90-91 are green, 92+ are black
D series are blue, still are round and function the same.
97+ prelude are green and square
99+ CRV is brown and square and function the same as the prelude ones
Im sure honda uses more knock sensors on other motors, im just not familar with them
Know your knock sensors! hehe
Oh,btw, all honda 1 wire knock sensors function the same. If you are adding a knock sensor just use the corresponding plug and it will work fine.
The reason I asked was to make sure we had what the customer wanted - they all work the same but if his harness has the square plug he might be a bit unhappy if we sent him the round knock sensor ( 88-91 b16 ) But thaank you for the info we copied it for or records
