Rear main seal & Pilot bearing??
Old Jun 20, 2004 | 08:39 AM
LUDERH22's Avatar
Default Rear main seal & Pilot bearing??
How hard are these to change compared to a timing belt and seals change on a h22a.
Old Jun 21, 2004 | 08:51 AM
LUDERH22's Avatar
did the search found nothing, has anyone ever done this?
Old Jun 21, 2004 | 09:14 AM
Speedra500's Avatar
Default Re: (LUDERH22)
it would be quite a bit of work, you would obviously have to drop your tranny and remove your clutch and flywheel, then take off your oil pan and remove the crankcase side plate, you'll probably have to knock out the old seal with a screwdriver from the back and then hit the new one in with a rubber mallet, then go get some hondabond and apply a thin layer to the crankcase surface after you have cleaned all the old hondabond off and bolt it all back together
Old Jun 21, 2004 | 09:48 AM
lildrgn2.0's Avatar
New User
Default Re: Rear main seal & Pilot bearing?? (LUDERH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LUDERH22 &raquo;</TD></TR><TR><TD CLASS="quote">How hard are these to change compared to a timing belt and seals change on a h22a.</TD></TR></TABLE>
H22's dont have a pilot bearing.
I would think shouldnt take more than a weekend for the Main Seal. It only took us a day, but we had the engine out.
Old Jun 21, 2004 | 12:41 PM
Behan's Avatar
Default Re: Rear main seal & Pilot bearing?? (Lildrgn)
i just did my clutch this weekend, with the engine in the car. started work at 1 pm stopped at 9pm ( had the tranny back in). started again in the morning ( 10 am) and put everything else back together by about 1 pm.
I was taking pics of each step for a write up though, so you could be done in less time.
Old Jun 21, 2004 | 03:18 PM
LUDERH22's Avatar
thanks for the replys i have to take the trany out any ways for a new act xtss clutch & CM Flywheel, doesnt seem hard just alot of work. Im interested in seeing the write up...behan .thanks again
mclasser
Dec 25, 2013 11:41 PM
hidiouskinky
Jun 23, 2008 07:26 PM
dope
Mar 8, 2008 05:25 AM
xXSilentScreamXx
Aug 15, 2007 05:42 AM
godsider
Feb 25, 2006 03:03 PM
