Water lines for t3 turbo...... where to run um?
i'm almost ready to start piecing my setup together... and i got my turbo yesterday, its a used t3 60trim, and when i got it i noticed it was water and oil cooled... now ive searched on wether to even bother with the water lines.. and i think i'm going to .. but i was just wondering where to draw from and return the coolant too?.... i have a 92 accord with a jdm h22a in it.. thanks in advance!!!
I think it's a waste of time/space/resources to run the coolant lines personally. But if you need to, most people run the turbo in series with the throttle body/ iacv lines. I would put the turbo after the TB so you do not heat the intake air more than it already is....actually now that I think about it i'm not sure if the h22 has these lines. guess you should just go and look.
lojackgsr
Apr 27, 2008 03:03 PM
