Removing OEM side skirts (searched)
Check out the Team-Integra.net articles: http://www.team-integra.net/se...D=739
they are the plastic screw clips.
You screw them out as much as they can, then pull them out. Once all of those are out, and the screws in front and back are out, slide the side skirt towards the front of the car and it will come off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excel88 »</TD></TR><TR><TD CLASS="quote">Are u able to re-use these, is my main issue</TD></TR></TABLE>
yes
yes
if you plan on putting them back on, you should twist out the white plactic clips off of hte body of the car and slide them into the side skirt, then the whole assembly will just snap back into place, no fussing around.
You first unscrew 3 bolts i think it was on teh ends of the side skirts.
Then you push the side skirts toward the front and it pops rite off
To take off the clips, twist the clips around and pull, you';ll see what i mean when you get to this point.
The easiest way to put the side skirts back are to take ALL the clips off.
Put all the clips onto the side skirt and just push the side skirts into the body of the car. There is no need to slide them back like how you did to take the skirts off.
Sorry if what i wrote made no sense. if any more questions just PM me and i'll be gladly to help you to my fullest extent.
