tokico illuminas
Usually you'd go the other way around...pick out the springs you want, then find a complementary shock.
But if you want to do it this way, Illuminas will work great with just about any spring you choose. They'll hold up to stiffer spring rates, and since they're adjustable, you can adjust them to complement softer rates as well...depending on how you like your ride.
Alex
Alex
They should do fine with that setup, although for the $...I'd probably suggest Koni's over the Tokico's. Are you looking at the H&R race spring set?
I have Skunk2 coilovers with Illuminas in the rear, and they seem to do a great job with the fairly stiff Skunk2's. The only reason that I suggest the Koni's is because the H&R race springs have a stiffer spring rate than the Skunk2 coilovers, and Koni's can handle higher rates than the Illuminas can.
Alex
Alex
I would also do a search here on H-T, and find out if any other users have that combo (H&R Race with Illuminas) and find out what they think about it, how it's holding up, etc. I think it should be a good setup, but I'd just make sure if I were you.
Alex
Alex
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHiTe91hAtChBaCk »</TD></TR><TR><TD CLASS="quote">i wanna get neuspeed springs..either race or sport...and i am kinda thinking tokico illuminas that is why i asked...is that a good set-up...or would agx be better?</TD></TR></TABLE>
For the Neuspeed Sport springs, either shock would be good. I have Neuspeed sports for sale, $80 for the set, check my sig
For the Neuspeed Race springs, I'd even be a little sketchy about using the Illuminas, even though they're more durable than the AGX's. The Neuspeed Race rates are REALLY high (in the 500's) for a street car, and they've got a really low drop to them. Go with Koni's if you can for that particular setup...
Alex
.For the Neuspeed Race springs, I'd even be a little sketchy about using the Illuminas, even though they're more durable than the AGX's. The Neuspeed Race rates are REALLY high (in the 500's) for a street car, and they've got a really low drop to them. Go with Koni's if you can for that particular setup...
Alex
everythingwentblack
Suspension & Brakes
Feb 1, 2010 02:31 PM
Sobe_Death
Jul 3, 2005 11:28 AM
Norcalstoppy
Dec 9, 2002 04:49 AM
