Aircraft remover on rims....
Old Jun 19, 2004 | 10:25 PM
Dumped DB2's Avatar
Default Aircraft remover on rims....
I am planning on paintin my GSR fat fives tomorrow and I have bought 2 cans of aircraft remover, one can of primer and 2 cans of flat black spray paint...my question is...when i spray on the aircraft remover, how long should I let it sit on the rims and how should i clean it off after that? also do you have to sand the primer after u spray it on or just paint it? any help would be appreciated!
Old Jun 19, 2004 | 10:28 PM
ElementMotor's Avatar
Default Re: Aircraft remover on rims.... (Pjct2ndGenTeg)
It shouldn't take long at all for it to start working. Maybe 10-15 min, then I would use a wire brush of some kind to scrape the excess off. Be sure to wear gloves! that **** is nasty!
Old Jun 20, 2004 | 12:29 AM
YEE*MagicEK20kombobomber's Avatar
* B A N N E D *
Default Re: Aircraft remover on rims.... (z6Ferio94)
no joke wear gloves. that **** burned a hole in my skin like whoa! use a wire brush as said above and spray off with high pressure water.
Old Jun 20, 2004 | 12:31 AM
Fishbone Walker's Avatar
I'll third the gloves recommendation. That stuff is dangerous.
Also, make sure you have adequate ventilation.
Old Jun 20, 2004 | 12:58 AM
ALLBLINE's Avatar
Default Re: Aircraft remover on rims.... (Fishbulb)
If it gets in your eyes go to the hospital. Saw this kid using it one time(aircraft paint remover) and ice didn't bring down the swelling,i was lol though. Kid did't go blind thanks to eye flush and the emergency room.
Old Jun 20, 2004 | 01:14 AM
jboy_415's Avatar
Default Re: Aircraft remover on rims.... (ALLBLINE)
where do you get that remover from?
Old Jun 20, 2004 | 01:20 AM
Declectic's Avatar
Default Re: Aircraft remover on rims.... (jboy415)
i used it to strip off what i had done to my rims lol clicky
Old Jun 20, 2004 | 05:56 PM
ceLtic's Avatar
N/A wh0re!
Default Re: Aircraft remover on rims.... (SeanJohn1802)
can i use it with the tires on the rim? and a lot of masking tape?
Old Jun 20, 2004 | 05:59 PM
authentic plusONErandy's Avatar
wear goggles and a mask haha... dont do that **** outside if its windy... it blew on my face once ... lesson learned..... u can feel instant burning haha... i ran to the fauccet and drowned my face with water... luckily it worked
Old Jun 20, 2004 | 06:13 PM
ceLtic's Avatar
N/A wh0re!
Default Re: (_randeEe)
ok, if i use this on rims, can i mask the tires, and then scrub the paint/polish off?
and stupid question, since the finish is stripped or would be stripped, would the rims rust at all?
Old Jun 20, 2004 | 06:58 PM
no need to mask tires, they wont do anythign to it... besides the remover will eat through the tape like nothing so it will be obsolete... basically u just spray it on and let it sit for like 10 minutes rinse it off, and it will always have spots that were missed, so just spray it again witht he remover and repeat teh process... some occasional scrubbing would ease the process as well.... rims should not rust if theyre made of alloy which most likely they are
Old Jun 20, 2004 | 07:10 PM
kefka's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">i used it to strip off what i had done to my rims lol clicky
</TD></TR></TABLE>did tha air stripped eat your valve stems at all?
Old Jun 20, 2004 | 07:32 PM
hrmm i wouldnt try it, plastic cannot survive
Old Jun 20, 2004 | 07:37 PM
iHATEspeedbumps.'s Avatar
where can i get this aircraft remover?
Old Jun 20, 2004 | 07:40 PM
Ivan's Avatar
senior gold member
Default Re: (lDneGeL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lDneGeL &raquo;</TD></TR><TR><TD CLASS="quote">where can i get this aircraft remover?</TD></TR></TABLE>
autozone has it.
Old Jun 20, 2004 | 10:12 PM
kidkombo's Avatar
why dont you just follow the directions on the can....those usually work best
Old Jun 20, 2004 | 10:52 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fishbulb &raquo;</TD></TR><TR><TD CLASS="quote">I'll third the gloves recommendation. That stuff is dangerous.
Also, make sure you have adequate ventilation. </TD></TR></TABLE>
Heh... man up! When I used that **** on a valve cover, I had rubber gloves on, but the damn wind was blowing (wasn't going to spray that **** inside the shop) and the wind blew some mist onto my leg (wearing shorts). Kinda had that burning sensation but I just sprayed water on it afterwards
But I do agree about the goggles/glasses part, especially if you use it outside.
Old Jun 20, 2004 | 11:10 PM
Declectic's Avatar
Default Re: Aircraft remover on rims.... (endyn'ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by endyn’ed &raquo;</TD></TR><TR><TD CLASS="quote">did tha air stripped eat your valve stems at all?</TD></TR></TABLE>
nope not at all .. . i wouldnt recommend doing it with tires on. . .i was gettin new tires so it worked ot for me.. kind of made the side walls a lil bubbly. . . you can do it though, i dont think it will harm it.. just spray really closely and try NOT to get it on the tires..
and like said up above.. if its windy outside DONT DO IT! go in teh garage if you HAVE to do it
LaCuRa
Feb 1, 2009 09:46 PM
jyracer
Nov 14, 2008 02:18 PM
Nicram
Jul 14, 2005 01:20 PM
DreamAtlantis
Jun 6, 2005 02:13 PM
CRX_GUY_123
Mar 10, 2004 09:55 PM
