Putting a 91 CRX Si Motor in an 88 CRX DX Auto
Old Jun 19, 2004 | 08:52 PM
freeeked's Avatar
Default Putting a 91 CRX Si Motor in an 88 CRX DX Auto
I am considering dropping my old 1991 CRX Si Motor into an automatic 1988 CRX dx. I have an 1988 crx engine harness for the D16a1 motor. Also the ECU, linkages, headers from the 91 as well as all the other stuff. I also have an 88 part car with the manual pedal assembly.
What other hurdles will I be looking at? Such as axles, shift linkage exhaust, cables and such.
Old Jun 25, 2004 | 10:07 AM
freeeked's Avatar
Default Re: Putting a 91 CRX Si Motor in an 88 CRX DX Auto (freeeked)
bump still askin'
Old Jun 25, 2004 | 10:25 AM
91hob20hb's Avatar
Well obviously the most important thing is converting to mpfi and converting from auto-manual(unless you wanna keep the auto dx tranny)Axles i'm not sure which ones to go with for sure but you might have to have them cutom made with the inner shaft being from a si and the outer from a dx(remember that having to change axles is only needed if you swap to manual tranny)(on my 88 hf i used the stock hf axles when i swap my 90 crx si motor in)But a dx has different spline count on the hub end .you will need a shift linkage from a 88-91 any model.stock si header will bolt right up.I cant think of anything else right now but if i remember i will let you know
Old Jun 28, 2004 | 05:05 AM
freeeked's Avatar
Default Re: (91hob20hb)
Thanks, I have a full set of swap stuff. So the hubs on the dx have a different config than the SI. I have the Si axles and will probably switch the dx to auto. From the sounds of it I will have to scam some si hubs.
Old Jun 28, 2004 | 05:24 AM
Andzey's Avatar
and what about Vtech wiring - U have any idea about some link for manual ????
thanx
Old Jun 28, 2004 | 05:25 AM
crx_88_si's Avatar
no. the DX/Si have the same hub spline counts. its the HF that has the odd ball # of splines.
Old Jun 28, 2004 | 05:34 AM
Andzey's Avatar
Default Re: (crx_88_si)
Im looking to find some manual or any .pdf file about how to config Vtec - dont U all know any site ????
HELP
Old Jun 29, 2004 | 09:29 PM
freeeked's Avatar
Default Re: (Andzey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andzey &raquo;</TD></TR><TR><TD CLASS="quote">Im looking to find some manual or any .pdf file about how to config Vtec - dont U all know any site ????
HELP </TD></TR></TABLE>
The SI motor is D16 no VTEC. Are you trying to wire a VTEC (B16a) into your CRX. I have the info on that (It's just 4 add wires)?
B20Wannabe
Jan 10, 2012 11:08 AM
calm_down1
Nov 18, 2009 07:31 PM
gutted-dx
Jan 10, 2005 06:46 AM
Red_Si
Dec 16, 2003 08:13 PM
PhatboyNYC
Jul 20, 2002 06:10 PM
