HOw hard will this be?
Old Jun 19, 2004 | 07:58 PM
JoeCDN's Avatar
Default HOw hard will this be?
I was wonderin how hard it would be to swap an d16z6 in to my 92 civic dx?
Thanks
Old Jun 19, 2004 | 08:00 PM
93Civac's Avatar
Very easy. I believe the 92 DX already has the wireing for VTEC in the chassis harness, so all you need is the motor and ecu, and everything is a direct plug and play deal.
EDIT: You will also need the engine harness also.
Modified by 93Civac at 5:26 AM 6/20/2004
Old Jun 19, 2004 | 08:02 PM
JoeCDN's Avatar
Can anyone back him up?
Old Jun 19, 2004 | 08:04 PM
JDMlyfestyle's Avatar
i dont think the dx is prewired for vtec. i believe its the vx or cx. but its a straight bolt in. all you need is the P28 ecu then your all good. this was my first swap and we did it easily in 8 hours
Old Jun 19, 2004 | 08:06 PM
JoeCDN's Avatar
Soo what kind of wiring problems would happen? And does it matter that I have an auto tranny?
Old Jun 19, 2004 | 08:12 PM
Deemeetree's Avatar
Electrician
Default Re: (93Civac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93Civac &raquo;</TD></TR><TR><TD CLASS="quote">Very easy. I believe the 92 DX already has the wireing for VTEC in the chassis harness, so all you need is the motor and ecu, and everything is a direct plug and play deal.</TD></TR></TABLE>
Like I said before. I'm ******* tired of people giving bad information and not knowing **** to begin with.
DX models are NOT wired for VTEC. I BELIEVE the only ones that were wired for VTEC on the 5th Generation chassis (1992-1995) were the VX, EX, and Si. The EX and Si came with the D16Z6 motor which is a SOHC VTEC motor and the VX, I BELIEVE, was a SOHC VTEC-E motor. I'm not COMPLETELY sure on the VX, but I think I might be on the right track.
Swap should be plug and play. All you'll need to do is run wiring for VTEC and I do believe something else that escapes me right now. Search and you should find some things out, there's a few topics on this already.
Old Jun 19, 2004 | 08:20 PM
hatchling37's Avatar
Default Re: (Dimi)
Dimi, you're right on.
BTW, if you get stuck and nothing you search for yields results (if you don't find anything, read the thread on how to search) you might consider PM'ing Spade or BauleyCivic. Everything I've asked them, they knew right away.
Sorry in advance if this causes headaches to the D-Series fanatics
Jimmy's Avatar
Global Moderator
Default Re: (JoeCND)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoeCND &raquo;</TD></TR><TR><TD CLASS="quote">Soo what kind of wiring problems would happen? And does it matter that I have an auto tranny?
Now your talking about a WHOLE nother boat..when you said auto to manual conversion.
Old Jun 19, 2004 | 08:30 PM
93Civac's Avatar
So I guess honda fucked up when they put my buddies 92 Honda Civic DX 4 door toegether. All he did was put the motor in with the harness and pluged the computer in and viola it runs and vtec does work. Not to mention ive been told this by a few other people around here but oh well, if its useless info then so be it.
Old Jun 19, 2004 | 08:31 PM
99blackcivicSi's Avatar
Default Re: (Jimmy)
all 92 Civics are pre wired for Vtec look for B18c5_EH2's posts abouts about it, get a new ECU and plug it all up man
Old Jun 19, 2004 | 08:33 PM
JoeCDN's Avatar
I never said I wanted to do an auto to manual conversion...I know all about that..That might be in the future! LOL One piece at a time! LOL
Old Jun 19, 2004 | 08:34 PM
JV's Avatar
JV
Who?
Default Re: (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">all 92 Civics are pre wired for Vtec</TD></TR></TABLE>
Old Jun 19, 2004 | 08:35 PM
JoeCDN's Avatar
Well thanks for the info..BUt is there any webpages or honda sites to make 100% sure? or Do i have to take you guys words? JK!
Old Jun 19, 2004 | 08:37 PM
93Civac's Avatar
Default Re: (Dimi)
So about this useless info and not knowing ****........... looks like the shoes on the other foot buddy!
Old Jun 19, 2004 | 08:39 PM
simplegreenmachine's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">all 92 Civics are pre wired for Vtec look for B18c5_EH2's posts abouts about it, get a new ECU and plug it all up man</TD></TR></TABLE>
agreed
Old Jun 19, 2004 | 08:50 PM
JoeCDN's Avatar
HOw much are ECU's?
Old Jun 19, 2004 | 08:59 PM
93Civac's Avatar
I got a p28 out the local junkyard for $50, they can range from that to over $100.
Old Jun 19, 2004 | 09:05 PM
sleepereg's Avatar
http://www.car-part.com usually has the cheapest P28's I've seen in the last year. You're lucky if you find them less than $100 in good shape though...
Old Jun 19, 2004 | 09:10 PM
Deemeetree's Avatar
Electrician
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93Civac &raquo;</TD></TR><TR><TD CLASS="quote">So about this useless info and not knowing ****........... looks like the shoes on the other foot buddy!</TD></TR></TABLE>
Ok dick. You said the 1992 DX are wired for VTEC you didn't say that all models of 1992 were wired for VTEC. THAT'S where I came in. If you had mentioned all were wired for VTEC, it would've been another story.
Old Jun 19, 2004 | 09:19 PM
Ajax's Avatar
Default Re: (Dimi)
Why don't you both get over it. You were both technically wrong, both of you didn't provide enough information to make your statement 100% right.
And, so what your saying is that all 92s were wired for Vtec, but 93-95 and up weren't? What about 96 and up? Just looking to learn some more info
Old Jun 19, 2004 | 09:20 PM
93Civac's Avatar
Ok *******. The reason I said the 92 DX has it is because (if you didnt notice) HE HAS ONE!
And if you go back to your post you said the DX is NOT wired for vtec. So it would have been ok if I said all models but its not ok that i said that the specific model he is asking about has it. Whatever!!!
Yeah not all the 93-95 Civics are wired, which sucks cause i have a 93 DX. And im pretty sure the 96 up are not all wired either.
Old Jun 19, 2004 | 09:29 PM
93Civac's Avatar
I know where I can pick up a automatic p28 for $100, its in a local junkyard but I cant say if its good or not.
Old Jun 19, 2004 | 10:49 PM
SLowCrx's Avatar
Default Re: HOw hard will this be? (JoeCND)
Just put a D16z6 swap in my 1992 CX Hatch. It was all plug and play no wires added anywhere. Im using a P28 ECU... All 92 Civics are wired for VTEC (CX,DX,LX,VX,Si)
Old Jun 19, 2004 | 10:57 PM
The Airman's Avatar
Default Re: HOw hard will this be? (SLowCrx)
all 92 models are prewired. 93-95 only VX SI EX.
Old Jun 20, 2004 | 07:12 PM
JoeCDN's Avatar
Well thanks alot guys! Ill try to find a automatic p28 in the local junkyards...
