newer prelude hubs fit type r
just curious to know if anyone knew if the newer prelude hub would fit a type r.also,wanted to know if the prelude had the larger spline on the outboard joint like the accord?i was thinking of trying to make some axles,just want the larger outer spline and no, i don't want to buy the aftermarket ones,that would defeat the purpose.
Modified by turbotypeR at 10:27 PM 6/19/2004
they do have the larger splines.i have one in the shop right now and i am going to check the hubs just for the heck of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR »</TD></TR><TR><TD CLASS="quote">thanks.i guess i am going to have to bend over and buy the aftermarket ones</TD></TR></TABLE> The Ted Bundy of axles is finally catching on. haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxpsi »</TD></TR><TR><TD CLASS="quote"> The Ted Bundy of axles is finally catching on. haha</TD></TR></TABLE>
very funny
very funny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psiCiv »</TD></TR><TR><TD CLASS="quote">Too busy? That is a good thing, right? </TD></TR></TABLE>
yeah,i guess.still trying to figure that one out
Get back to be on your findings...because I was thinking of doing something similar because Im a cheapass.
Prelude Hubs redrilled for 4 x 100 ( I believe they use a different size Wheel Bearing, but the hub could be machinied for it.)
Then use JDM ITR Axles w\ 36mm Spline. Or even an aftermarket axle with my OEM 36mm Hub. *Shrugs*
For you car, I would just buy the JDM ITR 5-lug front, they are cheap.
