CEL #7 After flood
Old Jun 19, 2004 | 05:46 PM
ITR-00-1457's Avatar
Default CEL #7 After flood
I got a CEL # 7 today after I started my car, I know it is the TPS sensor. Is it true that you have to buy an entire new TB or could I just get the sensor?
Old Jun 19, 2004 | 11:26 PM
97mini-me's Avatar
Default Re: CEL #7 After flood (ITR-00-1457)
I've heard of people slotting their tps sensor rivets and taking it off. I am not sure if you can buy a brand new one (sensor only), but a local yard should have one. Any b series should work. Also, i think you have to re-calibrate it using a multimeter to get it set right. Anyone back me up?
Old Jun 19, 2004 | 11:58 PM
0554's Avatar
you can get a new sensor. i think honda sells them for like 35 bucks. just slot the rivet things and unscrew them. then yes you will have to recalibrate it with a multimeter. by the way did the car idle fine after you little water incident
0554's Avatar
also d series tps sensors are the same i believe
Old Jun 20, 2004 | 02:27 PM
Default Re: (88crex)
Well the CEL stopped going off today. I am not really sure why. Maybe there was still some water in the sensor yesterday.
Old Jun 22, 2004 | 01:27 AM
110 South's Avatar
You won't be able to purchase a new TPS from Honda...only a MAP sensor can be purchased. Any B or D series TPS will work. Use an oHm meter to set the TPS back into its proper position.
-Brandon
Old Jun 22, 2004 | 09:04 AM
Default Re: CEL #7 After flood (110 South)
Well the CEL is back, I really don't know what it wrond with it.
SIC_jdm_da9
Jul 11, 2007 03:59 AM
B!^A@
Aug 10, 2006 09:17 PM
EFRue57
Sep 17, 2005 05:41 PM
Combustion Contraption
Oct 22, 2004 04:08 PM
