DOHC ZC distributor question.
Old Jun 19, 2004 | 03:52 PM
EF_yo_89's Avatar
Default DOHC ZC distributor question.
alright this morning just before the eibach meet i went to get gas and as soon as the caravan was about to leave i got a check engine light. it read "8". which i found is TDC sensor.
with that code do i have to change my distributor since its within it?
which distributor is best for the dohc zc?
if i drove with the engine light on would anything be harmed?
thanks in advance
brandon
Old Jun 19, 2004 | 06:10 PM
StupidSlowRSX's Avatar
Nothing is broke.. If that car isnt running its probably because the ignitor went.. Very common amoung out dizzys unfortionatly..
As for replacement. 88-89 Acura Integra LS
Old Jun 19, 2004 | 06:29 PM
EF_yo_89's Avatar
Default Re: (StupidSlowCRX)
funny thing is the car is running fine, may be running even better? haha. thanks for the info.
Old Jun 19, 2004 | 08:15 PM
JonGP4's Avatar
Default Re: DOHC ZC distributor question. (EF_yo_89)
did u do the MPFI conversion on your car? usually a TDC sensor goes off for 2 reasons,
1.. bad connection
2.. Timing is way off
reset and see how long it takes for it to come back on, check all the connections, and check your timing .. i've never really seen one go out.. its just a magnectic pick up.. there isn't any wearable part in there.
janz3n
13
Sep 7, 2007 03:21 PM
89civich22
Oct 17, 2005 05:50 PM
NC-B17A
Nov 28, 2002 06:06 AM
