b16 2nd o2 sensor
Old Jun 19, 2004 | 01:56 PM
limpy's Avatar
Default b16 2nd o2 sensor
i want to hook up the 2nd o2 sensor in my crx with a b16 but don't know where the hell to run the wire. so where does it go?
Old Jun 19, 2004 | 02:06 PM
garlic jr's Avatar
Default Re: b16 2nd o2 sensor (limpy)
on hhu.com their was a link to this question... integra forum...
i think it was that if u had an obd1 system with obd2 motor u could run the 2nd o2 onto a piggy back tricking the ecu into thinking u have a working 2nd o2 sensor...
why the hell did u buy a obd2 motor? in a crx no less.. dont wanna know what that was like getting it to work
Old Jun 19, 2004 | 02:12 PM
Rywire's Avatar
Its c8 if you are running obd0.
PS, if it bogs, and hesitates then switch them around. Ryan
He never said it was obd2
Old Jun 19, 2004 | 02:36 PM
limpy's Avatar
Default Re: b16 2nd o2 sensor (droppedcrxsi)
c8 allready has a wire in it. do i tap into that wire or can i plug it into a pin some where else. it is obd0 by the way.
Old Jun 19, 2004 | 03:26 PM
Rywire's Avatar
This only works if you have the the wires comming out at you with the clip side up.
Old Jun 19, 2004 | 04:33 PM
limpy's Avatar
so it is the only one on the smallest clip that has no wire in it? what do i how do i put it in the clip?
Old Jun 21, 2004 | 10:26 PM
Tman's Avatar
I need to know this also...
Old Jun 21, 2004 | 10:40 PM
Rywire's Avatar
Default Re: b16 2nd o2 sensor (Tman)
I allready told you.
Old Jun 22, 2004 | 07:05 AM
crx_88_si's Avatar
this also might help in o2 placement..
Old Jun 22, 2004 | 08:12 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
You need to add a wire at C8 and wire the o2 sensors as shown:
Old Jun 22, 2004 | 08:37 AM
crx_88_si's Avatar
SAVED, great informational pics !
Old Jun 22, 2004 | 08:44 AM
EL Vap133's Avatar
Default Re: b16 2nd o2 sensor (88DXCRX)
Phil to the rescue!
Old Jun 22, 2004 | 09:17 AM
Rywire's Avatar
Default Re: b16 2nd o2 sensor (EL Vap133)
YA, there ya go!! Thats what I was looking for.
Old Jun 22, 2004 | 10:03 AM
nautica_t's Avatar
how do you tell which one is the primary o2 and which is the secondary o2, according to that picture, i have it switched around, would it make a difference if they were switched? TIA.
don't mean to hi-jack the thread.
Old Jun 22, 2004 | 11:12 AM
limpy's Avatar
Default Re: b16 2nd o2 sensor (nautica_t)
great pics that really helped. now how do i put the wire into the clip that goes into the ecu. isn't there a pin that goes over the wire that goes into the ecu? how do i get it in the pin?
Old Jun 22, 2004 | 11:25 AM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nautica_t &raquo;</TD></TR><TR><TD CLASS="quote">how do you tell which one is the primary o2 and which is the secondary o2, according to that picture, i have it switched around, would it make a difference if they were switched? TIA.
don't mean to hi-jack the thread.</TD></TR></TABLE>
If yours is running good, and there is no hesitation, its correct. If there is hesitation, switch them.
Old Jun 22, 2004 | 11:29 AM
88DXCRX's Avatar
If you have it switched,it will run like crap..and will be too rich..
Go here: https://honda-tech.com/zerothread?id=404493&page=1
and https://honda-tech.com/zerothread?id=404493&page=2
and read what a guy called "Camshaft" had to say..(2 pages)
P.S.&gt;If you do have them switched around,be sure to reset your ECU while
you are at it..
To wire it up you need an extra pin from a donor harness or an unused
wire if you have one.
For info on removing the pins,go here: http://www.deepstaged.net/rpecu4gb.htm
Old Jun 22, 2004 | 03:13 PM
nautica_t's Avatar
88DXCRX.
okay can i just take out the o2 sensor and switch spots. or are the actual o2 sensors built differently. cuz than i'll just switch the positions rather than re-splicing the wires. cuz right now, i guess you could say the primary o2 sensor wire is spliced into the secondary o2 sensor on the ecu pinout. and primary pinout wire is connected to secondary o2 sensor.
i don't got much bog.
only bog i get is when i'm in 5th gear goign about 110-115 KM/H at about 4 grand, it bogs there, if i put on the throattle it kinda chokes, so would changing my o2 sensor wiring correct this?
-&gt; and by the way, i'm suppose to connect the A/F ratio to the primary o2 sensor correct, it doesn't bounce liek all the other A/F ratio i seen. Thanks 88dxcrx, you've been a great help so far. very much appriciated.
Old Jun 23, 2004 | 07:19 AM
88DXCRX's Avatar
Yes,you can swap positions of the O2 sensors in the exhaust manifold..
That is what I would have done if I had known at that time..
Since my engine was already installed,
I figured it would be hell to get the sensors so
I just switched the two wires at the ECU.
For my car,having the o2 sensors wired correctly
made a big difference in the performance and drivability.
Good Luck,Phil
Old Jun 23, 2004 | 08:06 AM
nautica_t's Avatar
hey 88dxcrx, it feels a bit better now that i have changed the wires over, but we'll see how much response it has on the highway
thanks again bro. but i have another problem now lol
but i'll make a new thread.
Old Jun 24, 2004 | 01:37 PM
limpy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limpy &raquo;</TD></TR><TR><TD CLASS="quote">now how do i put the wire into the clip that goes into the ecu. isn't there a pin that goes over the wire that goes into the ecu? how do i get it in the pin?</TD></TR></TABLE>
Old Jun 24, 2004 | 01:47 PM
88DXCRX's Avatar
answered above:
Old Jun 24, 2004 | 04:07 PM
RCautoworks's Avatar
Little tip, the pic posted above showing the clips and numbers is a great pic but the pic is backward compared to how other sites list them, so just use 1 chart and you will be good.
Old Jun 25, 2004 | 01:20 PM
limpy's Avatar
Default Re: b16 2nd o2 sensor (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">answered above:
thank you that was what i needed to know. everyone should save this page for some damn good info!!
Old Jun 28, 2004 | 06:28 AM
luciffer's Avatar
I all ready have both my o2 sensors in, wired up and working correctly with the original white and green connectors.
But i want to replace the o2 sensors, so my question is are the two sensors the same and what is the replacement part no.
thanks
***Edit *** called my local honda dealer and for the o2 sensor from a 92-95 si they want $250 CND per sensor. I am i crazy or is this nucking futs? Has anybody replaced these o2 sensors with non OEM sensors? If so what brand and how did it turn out.
Modified by luciffer at 5:08 PM 6/28/2004
Modified by luciffer at 5:24 PM 6/28/2004
