Turn signals / dash lights dim when on, tach/temp gauge goes crazy
Old Jun 19, 2004 | 01:17 PM
OneZero1010101's Avatar
Default Turn signals / dash lights dim when on, tach/temp gauge goes crazy
Ok, this is bizaare. Tach / temp guage is fine durning normal driving. Soon as I turn on flasher, hazaards, or headlights, the tach and temp guage jumps, like it pulses with the lights. Anyone have any clue as to what could be causing that? Or if there is a specific relay / ground wires / plugs that I can check. Check your grounds dont help much, cause I dont know where to start and checking grounds if i was to start from scratch might be easier to just swap the whole harness out. Was hoping for a way to avoid that. If anyone has ever noticed this happening or can suggest a place to start would greatly appreciate it. Thanks. Also, my ecu is throwing Code 17 frequently now, but have not traced down the cause of it yet. Engine runs fine. Thanks
Old Jun 19, 2004 | 02:09 PM
garlic jr's Avatar
Default Re: Turn signals / dash lights dim when on, tach/temp gauge goes crazy (OneZero1010101)
might be that your alt can no longer supply the power needed for all of that... try a new 1. or 1 u know worked good.
DEPintheCurve
Feb 22, 2018 03:35 AM
mnskateboarder
Jun 22, 2009 01:11 PM
CaptainQuirk
Jul 11, 2007 12:09 PM
kell211
Jun 12, 2005 03:56 PM
InMyProject
Mar 16, 2005 07:49 AM
