Quick wiring question...
Old Jun 19, 2004 | 08:42 AM
anty's Avatar
Default Quick wiring question...
hey guys, i got a quick wiring question, i have a dvc sub and i was wondering what the best way to hook it up as? or does it even matter?
thanks
Old Jun 19, 2004 | 11:41 AM
o_Rage_o's Avatar
Default Re: Quick wiring question... (anty)
DVC allows you to run different wiring configurations - the most useful being 2 ohm if your only running 1 sub. assuming your amp can handle the load the 2 ohm wiring will give you more output (make sure your sub can handle the power).
If you bridge your amp in B (except across both channels), and use the dual voice - you'll run 1.3 ohm and your most likely not stable at it (read your manual).
B would also run only ONE of your stereo channels at 2 ohm, you might also need to consult your manual if this is allowed.
soooo i've given no answer lol sorry (i'm torn too) I would do A, assuming you do not have another sub or rears to use the unused channels on the amp in diagram B - because leaving them open like that is no good either.
I would also think you would have to run the amp in mono, if there is a switch...i've personally never used a stereo amp with a single DVC sub - i'm sure EBP, rcurley or the others will provide a better answer.
Good luck.
-Rage
Old Jun 19, 2004 | 04:15 PM
anty's Avatar
thats alright, you answered it very well, i think i'm gonna go w/ A - its a mtx 801d mono amp and an audiobahn alum 12Q sub. thanks again
Old Jun 21, 2004 | 12:33 AM
MCall's Avatar
run with the B configuration, accept brodge the unused + and -.. itll give ya all the power of the amp to the sub :0
Old Jun 21, 2004 | 01:35 PM
EBP_SI's Avatar
Default Re: (MCall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MCall &raquo;</TD></TR><TR><TD CLASS="quote">run with the B configuration, accept brodge the unused + and -.. itll give ya all the power of the amp to the sub :0
that would depend on the configuration of the voice coils. if they're dual 4 ohm then no, dont do that. You'd end up with a 2ohm mono load and likely go into protect mode. A lot of amps arent stable at 2ohms mono. If they're dual 8ohm then do it as you'll have a 4ohm load. configuration A & B are both correct but B gives you the option of adding another sub to the same amp. whatever floats your boat.
Old Jun 22, 2004 | 03:02 PM
sceg's Avatar
if its an 801d, you can wire it either way and get the same results because the amp is bridged internally, its a mono amp=only one channel, the 2 terminals are connected inside the amp.
milo
Audio / Security / Video
Jan 23, 2008 06:52 PM
Gouki133
Nov 27, 2006 08:50 AM
MilanoCivic97
Apr 19, 2006 07:12 PM
GroundZer0 336
Apr 17, 2004 08:54 AM
loki2323
Nov 19, 2002 09:34 AM
