Civic Speedometer not working
Old Jun 19, 2004 | 06:55 AM
swdubs's Avatar
Default Civic Speedometer not working
My 2000 Civic's speedmoter is acting nuts. It will only register as high as 20 miles an hour no matter how fast I am going. Somtimes it stcks at zero. Ohter times I am stopped and it stcks at 20.
Any ideas whats wrong ?
Thanks,
Old Jun 19, 2004 | 06:59 AM
Slow98sedan's Avatar
Default Re: Civic Speedometer not working (swdubs)
the speedo on my 98 dx is doing the same thing. Except it'll either stick @ zero...or go to the speed im goin,but drop back down to zero again...kinda like a tach.
any help??
..adam..
Old Jun 19, 2004 | 07:02 AM
Caveman74's Avatar
Its probably your VSS. Speed sensor
Old Jun 19, 2004 | 07:10 AM
swdubs's Avatar
Default Re: Civic Speedometer not working (Caveman74)
Is that tough to replace ?
Thanks,
Old Jun 19, 2004 | 10:03 AM
EG6 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swdubs &raquo;</TD></TR><TR><TD CLASS="quote">Is that tough to replace ?
Thanks,</TD></TR></TABLE>
Not at all, it is on top of the back side of the tranny. Unplug the connector and take out the 10mm bolts, then just pull it out. Thats all!
Old Jun 19, 2004 | 10:38 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Civic Speedometer not working (EG6 SiR)
sounds like your vehicle speed sensor is going out. they're interchangeable from other trannies that i'm aware of.
Old Jun 19, 2004 | 12:57 PM
neomystic22's Avatar
Default Re: Civic Speedometer not working (AzntaggeR)
just replaced my speed sensor it took maybe 10 minutes... easy enough a chick could do it
Old Jun 19, 2004 | 01:27 PM
Default Re: Civic Speedometer not working (neomystic22)
Sweet. Thanks guys.
Any idea how much one of these runs?(at a normal auto part store)
Someone mentioned above that they are interchangeable? So since I have a 98 DX (D16Y7)...what other ones will fit incase my auto parts store dont have mine?
..adam..
Old Jun 19, 2004 | 09:16 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Civic Speedometer not working (Slow98sedan)
try to avoid buying it from the auto part store if you can. i'm sure you can find it off of a bastard tranny no one wants for dirt cheap.
as far as interchangeability, when my the VSS in my GSR tranny went dead i swapped it from my D15 tranny. bolts and plugs right in.
Old Jun 19, 2004 | 09:23 PM
Chris y0!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neomystic22 &raquo;</TD></TR><TR><TD CLASS="quote">easy enough a chick could do it</TD></TR></TABLE>
MOST
Mar 1, 2007 10:24 AM
dylokjai
Dec 2, 2006 06:15 PM
FGride
Feb 18, 2006 09:37 AM
iblingidawg
Dec 17, 2005 11:18 AM
MUGEN-CRX
May 24, 2005 07:43 PM
