check engine light is on after i installed new headers
Old Jun 19, 2004 | 06:53 AM
marshallslp's Avatar
Default check engine light is on after i installed new headers
i just finished installing my new DC sports headers on my teg but the check engine light is still on. i looked over everything a few times and i cant find anything wrong with it. is this normal and is it an easy fix or should i take it to a professional mechanic and waste the money to have them figure it out
Old Jun 19, 2004 | 07:40 AM
LostAndFound's Avatar
Default Re: check engine light is on after i installed new headers (marshallslp)
did you connect your o2 sensor back. And reset the ECU. team integra has a article how to reset it...on your fuse box when looking at it fromt he front of the car the top left 2 fuses pull them. ECU and ECU backup they should be. Let it sit 5 min then restart teh car and let it idle for 10 min dont rev it. And if your throwing a code read the first thread on this page for what code your getting. Long blinks = 10 short blinks = 1 read how to use the jumper for the codes.
Old Jun 20, 2004 | 05:57 AM
Default Re: check engine light is on after i installed new headers (LostAndFound)
good call man.. thanx a lot.
Old Jun 20, 2004 | 08:31 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Pull the code, and see if you can figure out what it is based on that.
,or at least let us know what the CEL code is.
lemur1987
11
Nov 27, 2014 11:06 AM
ph0shizzle
May 13, 2006 08:36 PM
snouka
May 16, 2005 02:39 PM
HATCHFIEN
Nov 1, 2004 10:00 PM
type Gendy
Apr 21, 2003 04:48 PM
