What motor mount is this from?
Old Jun 19, 2004 | 12:59 AM
Tw1n Turb0 Z's Avatar
Default What motor mount is this from?
I was in the middle of swapping engines in my hatch. I traded someone straight up for a 60k Z6 for the 100k Y8 i was currently running. I thought that they had the Y8 motor mount in the car at the time but when I went to the junkyard to grab the EG motor mount they were the same. I checked my CRX motor mount and its different also, so I'm wondering if this came out of a del sol possibly or what?
Here are a couple of pics to clarify
This is of the mounts
This is of the old mount that was in it, which is also identical to the mount i found in the junkyard EG
Thx for the help
Old Jun 19, 2004 | 01:40 AM
si foo's Avatar
did u try turning it over? Also if u change the inner engine mount it will fit.
Old Jun 19, 2004 | 01:49 AM
Default Re: (si foo)
If you examine the pics there is no way the motor mount will fit. The spacing between the holes is too wide for the two studs on the motor mount. If you also examine the block-mounted mount, it has 3 mounting spots-two that the nuts go on, and one that the bolt goes in through pointing downwardds
I know that if i replace the inner mount It will work but I am having a bitch time getting teh crank pulleys off, so if i can just find the correct mount, set it in there and bolt it on, i'd rather go that way
Unless anyone has any good ideas for getting the crank pulley off? I soaked it with PB Blaster and hit it with a 650lb impact in reverse and the bastard didnt budge
Old Jun 19, 2004 | 03:48 AM
liam821's Avatar
25 Year Member
Default Re: What motor mount is this from? (Tw1n Turb0 Z)
The mount that connects to the engine, you can remove that. Pull the one off your old z6 and use it.
If you dont have it anymore, i think i have a few extra in my garage. You pay shipping you can have it.
liam
Old Jun 19, 2004 | 08:28 AM
gots_a_sol's Avatar
here is the mount you need:
mines broken though the rubber in the middle of it broke
Old Jun 19, 2004 | 08:31 AM
eL's Avatar
eL
So what mount is that?
Old Jun 19, 2004 | 08:33 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
you will have to use your Y6 mount arm and mount, and trim back the timming cover. its been discussed here in the boards recently. i think i read about it yesterday.
Old Jun 19, 2004 | 08:36 AM
Bakeoff's Avatar
Default Re: What motor mount is this from? (Built B16A)
just get the aluminum z6 mount that someone posted. It's the same as the 94+ teg mount. It will bolt right up to that.
Old Jun 19, 2004 | 09:07 AM
Default Re: What motor mount is this from? (Bakeoff)
So is this an aftermarket mount or was it only offered in a certain year? I have access to several other EG's I havent checked out yet, so If you've got the years they came in I'll gladly check one of them out
Old Jun 19, 2004 | 09:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">you will have to use your Y6 mount arm and mount, and trim back the timming cover. its been discussed here in the boards recently. i think i read about it yesterday.</TD></TR></TABLE>
Your description just confused me considering this motor is a Z6, and chassis is an EG. Why would I need to trim the timing cover for mount and engine that was built to be in my chassis?
I remember having to do this for my CRX when I Z6'd it, but dont understand why I'd need to do it here.
Old Jun 19, 2004 | 09:26 AM
Well I just found a guy 5 miles from me that has what I need. He swapped his EX so he had the mounts just lying around. Anyone know WTF they chose to use two different type of mounts in the EG?
Here is a pic of what he is giving me
Old Jun 19, 2004 | 09:39 AM
JDMFreak's Avatar
to me it look like the sameone, becuz it just a top view look it look different look closely at the alum. one and this one... i think it exactly the same execpt that picture is a rusted one
Modified by JDMFreak at 12:50 PM 6/19/2004
Built B16A's Avatar
looks like thats the ticket!
bunske123
Oct 10, 2007 10:50 PM
DeeCeeTwo
Jul 19, 2005 11:32 PM
Train
Jun 12, 2003 10:28 PM
