civic VX injector size? (stock)
Old Jun 19, 2004 | 12:17 AM
jaM3s Bond's Avatar
Default civic VX injector size? (stock)
Hola.
Dur ummm does anyone happen to know if the civic VX (vtec-e) is a 240CC injector like all the other (most) stock honda injectors??
thanks!
Old Jun 19, 2004 | 09:15 AM
BatuKing's Avatar
Default Re: civic VX injector size? (James Bond)
yes 240
Old Feb 27, 2006 | 06:03 PM
Hockey27925's Avatar
Default Re: civic VX injector size? (BatuKing)
no they are prolly not, the average person on this forum thinks that every honda/acura injector is 240cc/min but the fact is that on the d series honda i believe that those injectors are much less as in 170-180cc/min, its been tested
Old Feb 27, 2006 | 06:08 PM
Luserkid's Avatar
Default Re: civic VX injector size? (Hockey27925)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hockey27925 &raquo;</TD></TR><TR><TD CLASS="quote">no they are prolly not, the average person on this forum thinks that every honda/acura injector is 240cc/min but the fact is that on the d series honda i believe that those injectors are much less as in 170-180cc/min, its been tested</TD></TR></TABLE>
If its been tested how come you believe. I have never heard of a 170-180cc injector. The only 190 honda injector i heard is obd0 injectors. All other B and D are 240cc then H, F, K are different. If its been tested show the test results.
Old Feb 27, 2006 | 06:50 PM
eXcelonTypeR's Avatar
Yup, 240cc Saturated. used my VX injectors on my Z6 motor when it was in my car, didnt have any problems for 14 months b4 i went DOHC. Now if was the smaller injectors, as some of the recent talk on this forum, the motor would of ran lean and seized up, but it didnt
Old Feb 28, 2006 | 04:52 AM
Default Re: civic VX injector size? (eXcelonTypeR)
you should prolly check out the service manual for a 97 cx then, it clearly says that they use 190cc injectors
Old Feb 28, 2006 | 06:21 AM
thursday's Avatar
Default Re: civic VX injector size? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
If its been tested how come you believe. I have never heard of a 170-180cc injector. The only 190 honda injector i heard is obd0 injectors. All other B and D are 240cc then H, F, K are different. If its been tested show the test results. </TD></TR></TABLE>
this is how misinformation spreads. There is no factual bearing that all honda injectors are 240cc, look at the d16y7 for example.
i believe the vx and cx injectors are the same size and I have always assumed they are smaller than 240cc
Old Feb 28, 2006 | 06:34 AM
SkoundrelUSA's Avatar
cute little bastard
lol I'm so sick of this debate. Since I have a set (refer to sig ) someone want to tell me how to test them?
Like if I put them in on a stock B16 will it run all fucked up?
Old Feb 28, 2006 | 07:59 AM
Default Re: civic VX injector size? (SkoundrelUSA)
not sure if there is a way to check them, only by plugging in scan tool n looking at the duty cycle n the a/f ratio
Old Jan 5, 2015 | 03:53 PM
tak209's Avatar
Default Re: civic VX injector size? (stock)
figured this might help someone out later on. vx injector size is NOT 240cc if you put that big of injectors in the z1 motor stock it will cause (as it did on mine) to throw a code (s). the proper injector size is around 190cc and a good way to tell what your injectors are is to check the injectors, and on the side of the injector there are four circles 0000 in the first circle there is a 5 then the next two are blank/empty and the last circle has a 5 so it would be 500A
and so there is proof once and for all here is a print out of a flow test done on the injectors. i have seen some others flow tested and they have been 185cc and running fine. but no where near 240cc like most of the community believes.
Old Jan 5, 2015 | 07:54 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
From the list at HAmotorsports the VX should be 240 (235).
The only motor from the 5th gen that was 180CC was the D15B8 USDM CX.
Code:
D16Y7 1996-1997 Honda Civic CX,DX,LX SOHC 16V I4 180
D16Y8 1996-1997 Honda Civic EX SOHC 16V I4 VTEC 240
D16Z6 1992-1995 Honda Civic EX,Si SOHC 16V I4 VTEC 235
D15B7 1992-1995 Honda Civic DX,LX SOHC 16V I4 235
D15B8 1992-1995 Honda Civic CX SOHC 8V I4 180
D15Z1 1992-1995 Honda Civic VX SOHC 16V I4 VTEC_E 235
D16A6 1988-1991 Honda Civic Si,CRX Si SOHC 16V I4 235
D15B6 1988-1989 Honda Civic,CRX HF SOHC 8V I4 180
D15B6 1990-1991 Honda Civic,CRX HF SOHC 8V I4 235
So if that is erroneous info it's pretty common misconception at most databases.
On the plus side, you know you can rob the USDM CX for it's injectors if needed in the future.
Old Jan 5, 2015 | 08:26 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Did you notice any improvement in MPG with the injector cleaning? I've been debating whether or not to have them serviced, but not really sure if it's worth it.
eH.
Old Jan 5, 2015 | 09:37 PM
tak209's Avatar
i have noticed a difference in mpg and performance also. ever since i was turned onto it with my FD i do it with all my builds. worth the money in my opinion. its only 18bucks a injector.
Old Jan 5, 2015 | 09:41 PM
tak209's Avatar
Code:
ya cx parts are also easier to come by. so far only other thing i have noticed that is compatible with the vx is the injectors and throttle body. i read a thread once on ecomodder that the cx injectors have a different spray pattern however i can not verify that rumor though.
Old Jan 6, 2015 | 08:05 AM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Thanks! I guess I've no excuse not to now.
eH.
Old Jan 6, 2015 | 04:29 PM
HondaPartsHero's Avatar
Technical Hero
Code:
92-95 CX/VX injectors share the same part numbers
06164-P05-A02
06164-P09-A00 I.P.T.
Old Jan 7, 2015 | 11:11 AM
baller status's Avatar
I can confirm that the CX/VX injectors are 190CC and all the others are 240CC.
Had mine done at Injector Rehab. Good people over there.
Old Jan 7, 2015 | 12:12 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
06164-P05-A02
Didn't even think of checking the OEM parts sites.
Old Jan 7, 2015 | 03:12 PM
ek9_beast's Avatar
^^ I had a tuner try to tell me my 190cc injectors were 240cc.. We swapped in a set of y8 injectors and the car ran rich. I don't know why its a debate when so many people have done manifold swaps(y7 to y8) and point this out. Cx/vx Same injectors
Old Jan 7, 2015 | 07:56 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Just for clarity.... USDM CX and all VX have same injectors.
Canadian CX has the 240CC injectors and do not share the same part numbers as either USDM VX or CDM VX.
USDM CX's are a rare breed in Canada, even rarer than the VX is in Canada. This is a nifty trick for those in the states.
Would hate to see some Canadian VX user read this thread and go off running to a salvage yard to grab CX injectors and then cause cylinder wash from running the car too rich.
Old Jan 7, 2015 | 08:00 PM
ek9_beast's Avatar
I always forget about our friends up north when I'm in this forum
Old Jan 8, 2015 | 09:08 PM
tak209's Avatar
yes i should have clarified that. good catch
i am also tired of hearing people tell me when i am looking for parts for my vx that ALL 1.5 d series will work. my vx i recently bought has a ex manifold on it with 240cc injectors. just a headache.
Old Jan 8, 2015 | 09:15 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Yeah that could get old pretty quick.
You can always use the OEM parts sites to compare parts between trim levels to see what is the same and whats not. It's pretty handy that way in my opinion.
Old Jan 9, 2015 | 02:28 AM
Technical Hero
Confirmed that that part number is shared with USDM 92-95 Civic with the D16Z6, D15B7 and is 240CC
dem0nk1d
Feb 4, 2007 11:25 AM
Excelerate
Mar 14, 2006 07:38 PM
JDM_EK3
Aug 22, 2005 10:07 PM
