Just installed integra seats into my hatch...fitment issue
i got integra seats...and there from a 2 door. The fronts fit great...but the rears...when i install them..they have a pretty big gap between them. I was told to get the "4-door" rear seats...the "pad" you sit on...to make a better fit...because they are bigger and sit higher. Is this right?
can i mod the 2-door rear seats to fit better? somehow?
I asked pretty much the same thing reguarding the ITR rear seats, and got pretty much the answer you have, the two door rear upper portion with the four door lower portion. Or you can just install them with some color matched carpet under them to make it look better.
I know you guys have eg's and I've got an ej but I'll tell ya what I did anyways......might somehow help....
I looked long and hard for info on putting gsr leather front and rears in my ej and didn't find a damn thing on it, so what I wound up doing was this:
1. Took the leather fronts from a 2dr and put them in my ej...redrilled the rear inside hole so all four holes bolted down....I'm **** like that....
2. Took the rear lower and upper from a 4 dr since it's 1pc and the 2drs are split like the eg's.....with some muscle the rear lower gsr seat fit in fine....had a small spot not covered by carpet since teg seats curve near the sides, but overall looked great...couldn't use the teg upper because it was too narrow-would've left a 2inch gap on each side so I took the gsr rear upper and the side bolsters that went with it and had an upohlstery shop sew the side bolster leather to the gsr upper leather and stretch it all over my civic upper....came out f'in sweet.....
I did read that 2dr teg rear uppers are for eg's though since they're split while ej's and 4dr teg rear uppers are 1pc....as for the rear lower I would go with a 4dr...it's wider and won't give you gaps on the side.....good luck...
https://honda-tech.com/zerothread?id=865053...there's pics that'll show ya how it came out....
