Need help!! b18a swap
Old Jun 18, 2004 | 11:22 PM
ef_Racer's Avatar
Default Need help!! b18a swap
ok i have a 88dx and we put a b18a 0bd-0 . Im throwing a code 9 and thats it. By the way wat is a code 9. Does it have a really bad affect on me. Because lots of smoke is coming out of my exhaust and sometimes it shoots like this black colored stuff like old oil or something. Whats wrong with my car?I guess im running rich and how would i fix that. It sucks i took it for a test drive and i cant see behind my rear view mirror because of all the smoke. I also have a question on the block what is the brown plugin. I believe its a sensor but i dont have a plug im using a si harness. Please respond to this
Old Jun 18, 2004 | 11:24 PM
ef_Racer's Avatar
Default Re: Need help!! b18a swap (ef_Racer)
help
Old Jun 18, 2004 | 11:36 PM
EF_LSVtec's Avatar
Code 9 (Crank Position Sensor)...usually when distributor bearing is failing you get this code...just replace your distributor.
*Brown plug located where on the block?
Old Jun 18, 2004 | 11:44 PM
ef_Racer's Avatar
Default Re: Need help!! b18a swap (EF_LSVtec)
could it b the reason for all this smoke??
Old Jun 19, 2004 | 08:08 AM
91civicDXdude's Avatar
i would double check your wiring before spending the bank on a new distributor.
Nathan_volcom
Oct 21, 2011 05:49 AM
scottso990
10
Aug 2, 2010 12:54 PM
jcyaj
15
May 30, 2007 05:14 PM
Dr.Octagon
10
Feb 15, 2006 04:18 PM
Eresuncabron
Dec 19, 2003 09:17 PM
