Clutch Problems - Searched
I was having a problem with the clutch in my freshly installed b18b1.. I searched and found that my fluid may be low causing the engagement point to be very low to the floor.. I added fluid and it raised it so little that it is barely noticable....
How can I adjust the clutch to engage a little higher?
BTW if it matters, I was told that the engine and tranny came with a stage 1 clutch and a stage 2 pressure plate... But he said that made the engagement point as crappy as it is, I don't see that being the cause.. someone help
Sorry if I didn't search hard enough...
you cant just add fluid and expect it to be woo woo woo back to normal. you gotta bleed it player...BLEED YOUR CLUTCH!
I wasn't positive on that because the last time I did that... ohh crap.. the last time I did that was to get the pedal off the floor of an 89 prelude after a clutch install........
Im a freakin idiot.. I'll do it tomorrow if I have time... leaky tranny and PS resevoir are jobs too..
Sorry about the dumb post
Thanks
Thanks
kneeslide
Transmission & Drivetrain
Feb 22, 2010 11:51 AM
