D-Series VSS in LS -- Jumping speedometer
Old Jun 18, 2004 | 10:24 PM
90civichb's Avatar
Default D-Series VSS in LS -- Jumping speedometer
I was told that it was alright to put a dseries vss in to the ls, that it would work fine..
It jumps occasionally.. whats the deal?
Old Jun 18, 2004 | 10:28 PM
hybridhondasquad's Avatar
Default Re: D-Series VSS in LS -- Jumping speedometer (90civichb)
problem more than likely in the diss not the vss
Old Jun 18, 2004 | 10:35 PM
90civichb's Avatar
Default Re: D-Series VSS in LS -- Jumping speedometer (hybridhondasquad)
Actually.. We noticed that there is a crack in the transmission today due to overtightening of the cap on the end of the tranny that wasn't supposed to be removed.. they torqued it on and cracked it..
This caused a leak of tranny fluid, could low tranny fluid cause the vss to mess up due to lack of lubrication?
anyone selling an LS tranny
Old Jun 18, 2004 | 11:32 PM
ej1 pilot's Avatar
get gsr or b16
Old Jun 19, 2004 | 03:01 AM
rob d's Avatar
Its most likely the wire connection. (vss plug) I had the same problem. Check the plug for corrosion.
Old Jun 19, 2004 | 01:10 PM
Shaun's Avatar
Default Re: D-Series VSS in LS -- Jumping speedometer (rob d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rob d &raquo;</TD></TR><TR><TD CLASS="quote">Its most likely the wire connection. (vss plug) I had the same problem. Check the plug for corrosion. </TD></TR></TABLE>
, corrosion... the number 1 leading cause to VSS deaths
ej1916
Jan 10, 2011 03:15 PM
95_red_dc
Jul 10, 2006 12:09 AM
95_red_dc
Jul 9, 2006 11:44 PM
92-LS-Civic
Dec 2, 2004 08:39 AM
